Ignition coil pack - Mustang Evolution
Old 05-13-2014, 10:01 PM   #1
TylerHo1313's Avatar
Ignition coil pack
I have a 2001 v6 abd wondering what would be recommended for an upgrade on the coil? I want something for performance but also to help out fuel mileage if possible. Also if swapping out coil what other parts be switched
Sent from my SAMSUNG-SGH-I437 using Mustang Evolution mobile app
TylerHo1313 is offline   Reply With Quote
Old 05-13-2014, 10:03 PM   #2
On an otherwise stock car it is a waste of money. You won't see enough increase in either to justify the costs.
Sent from my massive johnson.
Old 05-14-2014, 01:02 PM   #3
samuelsmith's Avatar
If you get a turbo or supercharger, get a Screaming Demon coil pack.
Old 05-14-2014, 08:44 PM   #4
Reason for asking I have a slight miss and its has new spark plugs
Old 05-15-2014, 08:38 AM   #5
Does the car have the original coil? When I changed my original one to a new motorcraft one it helped alot. No gains performance-wise but there was a difference over the original coil which was failing.
Miri is offline   Reply With Quote
Old 05-15-2014, 05:40 PM   #6
As far as I can tell from looks it is original. I bought the car in November and It has 135,xxx miles
Old 05-16-2014, 07:24 AM   #7
See if a new one helps. What plugs/wires do you have? I was told to always stick with motorcraft in my car
Old 05-16-2014, 07:47 AM   #8
I always stick with oe equipment but I wanted to see what people recommend
Old 05-16-2014, 01:03 PM   #9
From what I have herd an aftermarket coil pack will last as long as an oem one.
Old 05-17-2014, 01:42 AM   #10
lemons95's Avatar
I've heard of some few people having problems with aftermarket coil packs, i'm pretty sure mine is original still works fine with over a 160,000 miles on it.
« Brakes | Lowering »
coil pack or coil on plugs? Joe_Roma5 2005-2010 V6 Mustang 11 01-04-2013 09:20 AM
Ignition Pack photo needed bad Retired1SG Pre-2005 V6 Mustang 9 06-11-2011 11:05 AM
coil pack sledgehammer Pre-2005 V6 Mustang 13 01-13-2010 10:18 AM
ignition coil v6stang04 Pre-2005 V6 Mustang 6 01-09-2010 01:56 PM
Coil on Plug Ignition Coil Pack Set (8) 99-04 Mustang W/ Wiring Harness Cobra GT Mustang Parts for Sale and Wanted 7 12-28-2008 09:59 PM
05:04 AM
