F150 8.8 swap - Mustang Evolution
Old 05-24-2014, 03:35 PM   #1
BamaStang93's Avatar
F150 8.8 swap
I have a 99 v6. I've been wanting to do an 8.8 swap for awhile. I'm going the cheap route and pulling one from a local scrap yard. It's hard to come around gt rear axles around here but the f150s are plentiful. Now I know I've read on the forum that you can swap an 8.8 from an f150. My question is are there any major differences in the axle from an f150 and a gt axle? Splines? Gear ratio? Opinions would be greatly appreciated.
BamaStang93 is offline   Reply With Quote
Old 05-24-2014, 08:18 PM   #2
From another forum:
"4.6 F150s have 31 spline 8.8s
5.4 F150s have 9.75 inch rear ends"
Miri is offline   Reply With Quote
Old 05-25-2014, 09:12 AM   #3
Sluder4's Avatar
So what ratio would we need for our mustangs?
1999 V6 Mustang Dark Satin Green , SR CAI, BBK 65mm Throttle Body, Screaming Demon Coil Pack, SR Lowering Springs, Pioneer Stereo, 2 12' inch subs and 1600watt amp, Green Calipers,
Sluder4 is offline   Reply With Quote
Old 05-25-2014, 09:24 AM   #4
I'd measure the width of the rear axle because it seems to me that the truck rear ends are going to be much wider than the Mustang rears.
Old 05-25-2014, 10:23 AM   #5
Which takes me back to my first option. I guess I'll just keep looking for a parted out gt because I'm starting to think the f150 rear axle is going to be to large.
Old 05-25-2014, 02:49 PM   #6
Not only that but they mount up completely different.
It would be easiest to find one from a GT...
Old 06-22-2014, 08:27 AM   #7
UPDATE: Straybullitt was right. I just helped pull my buddies rear axle of his 01 GT. (Happy dance) so I'm about to rebuild this sucker. Just thought I should let y'all know.
Old 06-22-2014, 11:50 AM   #8
samuelsmith's Avatar
U do not know a lot about rear ends. I would not recommend you rebuilding it yourself.
Old 06-22-2014, 03:55 PM   #9
thanks for the great advice you offered.
Old 06-22-2014, 03:56 PM   #10
I'm not rebuilding it myself by the way.
Old 06-24-2014, 08:30 PM   #11
Markos's Avatar
Region: Iowa
Dont listen to Samuel lol you learn by taking stuff apart and putting it back together, if its wrong you fix it and learn for next time. Negative nancys grind my gears grrr
Sent from my SCH-R530U using Mustang Evolution mobile app
Markos is offline   Reply With Quote
Old 07-03-2014, 12:34 PM   #12
baddbradd's Avatar
if u run a 96-98 gt rear end. you'll need 1.5" spacers to make the wheel fitment look right
2001 coupe
baddbradd is offline   Reply With Quote
f150 5.0 swap? lemons95 Pre-2005 V6 Mustang 6 05-26-2013 01:15 AM
95 Mustang GT 8.8 swap from F150?? dmann415 1996-2004 Mustang GT 0 02-11-2013 09:29 AM
4.6 swap in to f150 monstr250 1996-2004 Mustang GT 3 05-31-2007 03:00 PM
New 2006 HD f150(harley davidson) sonic04edge The Bar 16 01-11-2005 03:58 PM
anyone see the new f150 commercial? Zim The Bar 1 03-14-2004 10:29 PM
08:12 PM
