2001 V6 - Mustang Evolution
Old 05-25-2014, 08:27 AM   #1
GodKreatedDude's Avatar
2001 V6
Difference between 3.73 & 4.10 racing gears? suggested ratio?
GodKreatedDude is offline   Reply With Quote
Old 05-25-2014, 09:10 AM   #2
Sluder4's Avatar
3.73 is for manual mustangs and 4.10 is for automatic.
1999 V6 Mustang Dark Satin Green , SR CAI, BBK 65mm Throttle Body, Screaming Demon Coil Pack, SR Lowering Springs, Pioneer Stereo, 2 12' inch subs and 1600watt amp, Green Calipers,
Sluder4 is offline   Reply With Quote
Old 05-25-2014, 06:43 PM   #3
thank you so much.
Old 05-25-2014, 10:01 PM   #4
mazen123's Avatar
Its not that simple at all. You can put any gears you want on any car. The reason why they say 4.10s are for automatics only is because first gear would be extremely short for a manual and shifting would be bothersome. The steeper the gear ratio the shorter you gears become BUT the bigger increase in movement you get. Stock we have 3.27 gears so 3.73s and 4.10s are a big upgrade to that but 4.10s are a nice upgrade compared to 3.73s. Then you factor in the gas mileage loss on the highway you get with steeper gears. Steeper gears cause your RPMs to rise higher compared to your stock gears for every mph. With our 3.27s in a 4 speed, we cruise at 70mph at 2100RPMs, with 3.73s probably 2400-2500 and 4.10s probably 2700-2800. This all causes gas mileage loss and extra wear on the engine. Its whatever you want in the end. Either way, 3.73s or 4.10s are both a massive upgrade opposed to stock gears, they will really wake up your car
mazen123 is offline   Reply With Quote
Old 05-26-2014, 08:59 AM   #5
Sluder4's Avatar
My point is proven then.....
Old 05-26-2014, 05:21 PM   #6
Mile high JDF's Avatar
I went 4.10s with my manual. If you're so concerned with highway gas mileage then why upgrade the gears? Or just cruise at a lower speed than 75. OP there's thousands of these threads out there, take some time and research them. At the end of the day it's all about what you want and what you are willing to deal with
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 05-26-2014, 05:50 PM   #7
I put 4.10s in my manual, after driving with them for a while I know 3.73s would have been a waste.
Old 05-26-2014, 07:28 PM   #8
Tangtang2.0's Avatar
Around how much did u guys pay for the gear swap
Tangtang2.0 is offline   Reply With Quote
Old 05-26-2014, 07:36 PM   #9
$200 labor on the condition that I helped my friend install it.
Old 05-26-2014, 07:37 PM   #10
I've been having my 4.10 sitting in my car too scared to call to see how much it'll cost me haha
Old 05-26-2014, 07:40 PM   #11
Expect the $400-$800 range depending on the shop
Matts 2001 V6 Coupe :: 2001 Ford Mustang fastmustangs1 Member Garages 0 03-24-2013 11:22 PM
2001 SVT Cobra :: 2001 Ford SVT Cobra 98StangKid Member Garages 0 06-22-2012 03:49 PM
My baby :: 2001 Ford 3.8 2001 coup Cjkingsman Member Garages 0 06-15-2011 12:01 PM
1965 to 2001 BruThru2002 The Bar 11 10-30-2003 02:50 PM
Need help with 3.8 to 5.0 switch for my 2001 V6 Stang. TrueStang01 The Bar 34 10-14-2003 04:50 AM
12:04 PM
