Weird idle - Mustang Evolution
Old 05-27-2014, 07:34 PM   #1
IWstangboy03v6's Avatar
Weird idle
So my car will drop down to 500 rpm sometimes for a couple of seconds. I took the IAC valve off and cleaned it. Also cleaned the throttle body. I put a cold air intake on and I've been changing the vacuum lines out. There are no leaks. Yesterday my check engine light came on. When I was driving home the idle would hang up around 1400 rpm when I was braking. I have a 2003 v6 . Please help
Sent from my XT1080 using Mustang Evolution mobile app
IWstangboy03v6 is offline   Reply With Quote
Old 05-27-2014, 07:52 PM   #2
TorchRed6's Avatar
whats the check engine light for? go to advanced auto or somewhere like that and have it checked out unless you have a tuner
TorchRed6 is offline   Reply With Quote
Old 05-27-2014, 09:23 PM   #3
I am not sure why its on. I assumed because of the idling issue. I will try to get my codes ran tomorrow
Old 05-28-2014, 10:02 AM   #4
lemons95's Avatar
my car does this when it's really hot(which is anything over 60 degrees where i'm at in cali, humboldt's weird...), which is weird, starts right up when it's cold though lol.
Old 05-28-2014, 10:08 AM   #5
Ed98v6's Avatar
IAC?
Ed98v6 is offline   Reply With Quote
Old 05-28-2014, 10:21 AM   #6
Site Sponsor
Sponsor
AMWill's Avatar
Get a hold of a CEL reader as soon as you can. Then we'll be able to more easily address the issue, depending on the code.
Have you changed anything else on the car recently? Such as the exhaust or O2 sensors? How long as this symptom been occurring exactly?
Provide us as much info as you can, so we can help you out!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 05-28-2014, 03:56 PM   #7
Its been dropping idle for about 4 days I guess. I got duals put on but that was almost 4 weeks ago
Old 05-28-2014, 04:43 PM   #8
Ed98v6's Avatar
My 98 v6 idles rough almost like a misfire, about every 3 seconds ill feel it shake once in the shifter and I can watch the motor bump if the hoods open, maybe we have the same problem
Old 05-28-2014, 05:23 PM   #9
Just got it scanned at auto zone and its something with the egr. All the codes pointed to something being faulty in it. I replaced the egr sensor with a cheap one. Could that be the product
---------- Post added at 11:23 PM ---------- Previous post was at 11:22 PM ----------
*problem
Old 05-28-2014, 08:19 PM   #10
Ed98v6's Avatar
My CEL is for bank two at its lean limit, hopefully just clogged injector
Old 06-03-2014, 09:09 PM   #11
I took it to the shop. They said the red hose I used to replace my vacuum lines was incorrect. They fixed it and my check engine light was off now back on. I put a cheap egr sensor on my car awhile ago. Could this be causing the check engine light?
Old 06-25-2014, 01:12 AM   #12
LadySleeper's Avatar
I've been having a similar issue, almost every time I slow to a stop it'll idle around 500 and shake like it wants to die. My light went on and I need a new O2 sensor and it's also saying the intake manifold is stuck open. Before that I cleaned out my idle air control and that little plastic connector on the vacuum lines broke so I put in a new one. This has been going on for a while now the light just didn't go on until recently so maybe it's just an O2 sensor?
Kierstyn
LadySleeper is offline   Reply With Quote
Old 06-26-2014, 07:52 AM   #13
I figured out that the aftermarket egr sensors will make the check engine light come on. I haven't replaced it yet but I need to put a motorcraft one on
---------- Post added at 01:52 PM ---------- Previous post was at 01:51 PM ----------
Check all of your vacuum lines and see if any are dry rotted or in need of replacement
Weird Idle MineralGrayGT 1996-2004 Mustang GT 5 03-19-2013 03:06 PM
Weird idle eouellette18 2005-2010 Mustang GT 7 05-10-2012 08:04 AM
weird idle 98StangGT 1996-2004 Mustang GT 4 08-31-2006 03:18 PM
OMG.. WEIRD.. so weird.. wiarumas The Bar 14 02-17-2005 12:45 PM
weird engine idle when hot 232SCstang Pre-2005 V6 Mustang 4 03-27-2004 12:08 AM
08:29 AM
