Mystery bucking - Mustang Evolution
Old 05-31-2014, 05:19 PM   #1
Chelley's Avatar
Mystery bucking
Hey guys, I have a 2000 base model auto with 237,000+ miles on it. The tranny was rebuilt 3 years ago, as was the rear end. I did the intake manifold gaskets and valve cover gaskets, replaced the MAF, DPFEGR spark plugs and wires. It needs a lot of work still but my main concern is the car bucks/shakes/knocks between 35 & 45mph with light pressure on the accelerator. I thought it was the MAF because the car ran better with it unplugged.
Any clues as to what could be causing it? The coil pack is my next bet.
Sent from my HTCONE using Mustang Evolution mobile app
Chelley is offline   Reply With Quote
Old 06-01-2014, 07:05 PM   #2
Ed98v6's Avatar
Mine did this too, it would buck and jump around 2000 rpm no matter wat gear I was in, I replaced the throttle position sensor sea foamed my intake and disconnected my battery for 5 minutes then reconnected it and let it idle for 15 minutes so the computer could relearn its idle pattern, idk which one did it mine stopped doing it, probably the tps, it was like 30 bucks
Ed98v6 is offline   Reply With Quote
Old 06-01-2014, 07:31 PM   #3
I had the same symptoms, then I bought a new ignition coil and it fixed that
It's apparently a common issue. Replaced at 140k miles
Miri is offline   Reply With Quote
Old 06-02-2014, 10:55 AM   #4
Chelley's Avatar
Some information to add. The bucking goes away if the car it's in neutral and reduces of I take overdrive off. I'm starting to think it's transmission.
Old 06-02-2014, 11:12 AM   #5
GrabberMeBlue's Avatar
It's a Mustang, it's supposed to buck and jump. Sorry, couldn't resist.
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 06-02-2014, 11:39 AM   #6
Mine did the same thing... Autoparts stores will have the motorcraft coil for $100. See if that fixes it before you dig around your tranny
Bucking issue. Please help FRslimmyjim 1979-1995 Mustang GT 20 01-26-2013 05:45 PM
AOD to T5 Swap & Idle, Bucking Issues Trojan Horse 1979-1995 Mustang GT 5 02-06-2012 09:47 AM
Bucking pony Kingmidas87 Pre-2005 V6 Mustang 11 01-20-2012 06:13 PM
95 gt rough idle and bucking issue Napoleon 1979-1995 Mustang GT 15 01-16-2012 04:09 PM
Bucking like a 'stang... IMP Pre-2005 V6 Mustang 1 02-16-2009 07:49 PM
11:59 PM
