Finally got a dyno in my area. - Mustang Evolution
Old 06-01-2014, 02:34 PM   #1
lemons95's Avatar
I was hoping for a little bit more HP, the torque impressed a few of the guys there though.
Old 06-01-2014, 03:10 PM   #2
Ish416's Avatar
110 max HP @4300, 210 tq @2000....
That seems way, way, way off. I'm not doubting the torque but the hp...
Me thinks there was either an error getting RPM or the dyno is not properly calibrated. A stock Dodge Neon would have made more hp. Post up the graph if you can.
Still .. going of that torque number, I bet that could be a fun car.
Old 06-01-2014, 03:36 PM   #3
lemons95's Avatar
Here it is.
Old 06-01-2014, 03:56 PM   #4
Ish416's Avatar
That car can't breathe.
Open up the intake, cam it and full exhaust and you should get some pretty good numbers.
You have any A/F readings?
Old 06-01-2014, 06:22 PM   #5
lemons95's Avatar
It runs a little lean, I'm saving up cash for a split port conversion+windstar, already have a set of heads. I'll probably get them ported, might do it myself I have some ****ty 5.0 f150 heads I could practice on.
Also some other things, I've been looking into, but I want to convert to splitport first.
Sent from my LG-MS770 using Mustang Evolution mobile app
Old 06-01-2014, 07:52 PM   #6
samuelsmith's Avatar
I am trying to figure out how you got it to run without a tune. My only guess is you used the original 3.8 cam.
I can give you SSMS port pictures but it is impossible to beat cnc heads. A flow bench is your only chance of getting close.
Old 06-01-2014, 07:54 PM   #7
lemons95's Avatar
The 4.2 cam runs okay without a tune.
---------- Post added at 08:54 PM ---------- Previous post was at 08:53 PM ----------
Started up first try when we built it.
Old 06-11-2014, 08:32 PM   #8
davidcseifert's Avatar
Region: Arkansas
Stock cams are small and not a huge difference between them. Remember single ports are rated at 145BHP which is about 119rwhp, the dyno isn't much off from where it should be which can be caused by weather as well, I was down 20hp on a humid A$$ day..
blower/new cam soon
Finally got my car to the dyno! And burning oil help please MC770 1979-1995 Mustang GT 45 09-27-2012 08:44 PM
Finally got to the Dyno! DWC_SmOziLLa 2011-2014 Mustang GT 9 05-13-2012 08:45 PM
Help In the Virginia Area (chesterfield area) gixxer007 The Bar 2 03-26-2011 07:52 PM
finally got my car dyno tuned! 07stang 2005-2010 Mustang GT 6 03-08-2009 10:05 AM
Well... I finally got my car on a dyno Yellow5.0 1979-1995 Mustang GT 8 04-23-2006 07:34 PM
09:49 AM
