3.73 Gears - Mustang Evolution
Old 06-05-2014, 07:38 PM   #1
MRYANWEBB's Avatar
3.73 Gears
I have an 03 V6 and was wanting to install 3.73 gears. I have quite a few questions about the gears and things surrounding them. Should I go with Ford Racing or Motive Gears, and why? I was also wanting to install a LSD. What years of a stock GT LSD would fit my rear end on my car? I don't have a lot of money to spend on a new LSD. Also, do I absolutely have to have a LSD with the gear swap? I know I would still do one wheel peels, but would there be any other real reason I'd need the Limited Slip. Would I still benefit performance and acceleration wise with just the 3.73 gears and no limited slip differential?
MRYANWEBB is offline   Reply With Quote
Old 06-06-2014, 02:37 PM   #2
lemons95's Avatar
I'm pretty sure none of the gt LSD's will fit your rear.
They don't make LSD's for the 7.5 anymore either, they're hard to come by. I think someone here has one for sale though.
A GT rear will bolt straight up to the V6 body, with no modifications. If you want a LSD that's the way to go.
When I swapped a 8.8 gt rear end in to my mustang I noticed it gets traction instantly, it'll screech them for a little,( I only have 3.27's though, better than my stock 2.73's though)
Old 06-06-2014, 07:02 PM   #3
samuelsmith's Avatar
The only thing to watch for in a 8.8 conversion is weather you have ABS or not. If you do not have ABS and the 8.8 you get does.........you will have to run the brake lines across the rear end your self. If you do have ABS it's easy. I figured out how to rig them. But I will not teach any one how to.
Old 06-06-2014, 08:23 PM   #4
lemons95's Avatar
I put my old 7.5 brake line the 8.8. I don't have abs.
Sent from my LG-MS770 using Mustang Evolution mobile app
Old 06-07-2014, 06:35 PM   #5
Thanks Lemons!
Old 06-08-2014, 08:16 PM   #6
MRYANWEBB's Avatar
Well, if I don't get the LSD and just do the 3.73 gear swap will I see a decent gain in acceleration and performance? A complete rear end swap probably won't happen for me since my dad passed and he did all of my mechanic work. Will the gears be worth the cost and give me a good get up and go?
Old 06-08-2014, 11:55 PM   #7
lemons95's Avatar
Yes you would.
I recommend the 8.8 swap with if your going to be getting lower gears.
Its actually a very easy swap. Its a bolt on mod.
I recommend getting a friend or two to help with lifting and maneurving the rearend, it's heavier than it looks.
Difference between 2.3 rear axle gears and 5.0 rear axle gears 93mstnglx 2.3 Mustang 9 07-07-2013 05:12 PM
4:10 gears vs 4:30 gears SwatKatz901 1996-2004 Mustang GT 5 03-24-2012 03:17 PM
3:55 Gears vs 3:73 gears 06Blue 2005-2010 Mustang GT 19 01-04-2012 06:57 PM
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
01:43 PM
