A/C Not Blowing? - Mustang Evolution
Old 06-08-2014, 05:18 AM   #1
TreyDeluxe's Avatar
A/C Not Blowing?
First off my a/c isn't that cold, hopefully just needs a recharge? Second when I do have the a/c on full blast it only comes out either the top vents by the windshield or the bottom feet vents??
TreyDeluxe is offline   Reply With Quote
Old 06-08-2014, 09:10 AM   #2
This happened to me.
What you have to do is remove the center console (the part with the radio, hvac controls etc)
Where the vents are above the controls, stick your hand in there, there's a flap thats supposed to open when your a/c is on. Whatever controls that flap in your system is broken. I just got a section of coat hanger and bent it so the bent end keeps the flap open, and the cut ends are braced against the inside of the center console, so it'll always be open forever. And have your a/c on while you do this so you know when it's all the way open
And yes you may just need a recharge
"Joey" 2004 v6: SR CAI, MPT Tuned, 4.10 gears
Miri is offline   Reply With Quote
Old 06-08-2014, 10:15 AM   #3
samuelsmith's Avatar
Check the 2 vacuum lines by the pass. side of the engine fire wall. 1 controls where the air blows and the other is the blend door. Your blend door could be open and that could be why u r not getting cold air.
Right side not blowing cold air Drakma675 2005-2010 V6 Mustang 5 10-14-2013 03:10 AM
My heater is not blowing hot air?!? bao General Mustang Discussion 4 03-03-2010 02:43 AM
A/C not blowing cold USMCSS 1996-2004 Mustang GT 4 05-30-2007 02:09 AM
Absolutely MIND BLOWING new website! Autobadges.com The Bar 14 04-07-2004 04:34 PM
Cubs are blowing it Brent The Bar 10 10-16-2003 06:17 AM
09:23 PM
