Small exhaust leak - Mustang Evolution
Old 06-08-2014, 12:59 PM   #1
Small exhaust leak
I have a little exhaust leak on one of the flanges on the drivers side, where the flange meets the tube section. Makes an audible ticking sound.
What products can I use for this? It's no more than an .5 - inch at most, or should I take it to get welded?
"Joey" 2004 v6: SR CAI, MPT Tuned, 4.10 gears
Miri is offline   Reply With Quote
Old 06-09-2014, 04:34 PM   #2
samuelsmith's Avatar
Is your car throwing codes?
Old 06-09-2014, 06:02 PM   #3
No. But I hate the sound when I turn on the car
Old 06-10-2014, 12:37 PM   #4
If you were showing O2 codes it would more than likely be your cats. If your cats were bad and you sealed up the leak the excess back pressure could potentially damage your engine and it would start leaking again. But you do not have this problem. So weld up the hole.
exhaust
found a small leak! with pic! helppp wootman101 Pre-2005 V6 Mustang 4 12-29-2013 09:14 PM
Small oil leak? v8pony 1996-2004 Mustang GT 2 10-30-2013 07:28 AM
small oil leak ??? 96mustangv8 1996-2004 Mustang GT 3 05-16-2011 01:44 PM
2001 Cobra fuel leak (I know wher3e the leak is) badcrc General Mustang Discussion 2 12-27-2008 11:54 PM
Evap leak Small jmarcinko00gt 1996-2004 Mustang GT 6 09-03-2008 10:26 AM
12:23 PM
