'04 4.2 swap questions - Mustang Evolution
Old 06-14-2014, 11:14 PM   #1
i currently own a '04 v6 5spd and the original 3.8 is blown. i'm wondering what year 4.2 would be the best for a replacement. hopefully someone can shed some light on this for me.
Dechstang is offline   Reply With Quote
Old 06-15-2014, 12:54 PM   #2
samuelsmith's Avatar
97-08
Pre 2005 V6: How to: 4.2L V6 Mustang Engine Swap
Old 06-15-2014, 01:31 PM   #3
so if i pick up a '99 4.2 long block i should be able to swap my oil pan, accessoires and lower and upper intake from my 3.8 directly onto the 4.2, reconnect and hook up everything and call it a day?
Old 06-15-2014, 06:39 PM   #4
lemons95's Avatar
You will need a new harmonic balancer and flywheel/flexplate.
Atleast I needed those, You may not need it if you have a 99-04 mustang.
Mine was a 1995 though and I know I needed those.
Old 06-15-2014, 06:52 PM   #5
ya i have a '04 mustang 5spd so im hoping i wont need that stuff but just would be great if someone knows for sure. i know the older sn95's needed more for the swap.
Old 06-15-2014, 08:38 PM   #6
Yea, including the lower intake on 99+ F-150 4.2. The 04 3.8 harmonic balancer and fly wheel are fine. Someone told me the 4.2 would need a tune, but Lemons did a single port 4.2 and his ran without a tune.
Old 06-15-2014, 08:57 PM   #7
Is there a guide with pics? I really want to see the process
"Joey" 2004 v6: SR CAI, MPT Tuned, 4.10 gears
Miri is offline   Reply With Quote
Old 06-16-2014, 02:09 AM   #8
lemons95's Avatar
You will get a check engine light without a tune, saying it's running lean. I have 10,000+ miles on this engine though. Only problem I've had with it is I don't think I got the rear main seal to seal all the way. It drops a little bit of oil. I check it every week though. It's not noticeable on the dipstick. I'm still in the safe range when I change my oil.
Sent from my LG-MS770 using Mustang Evolution mobile app
Old 06-16-2014, 11:02 AM   #9
I have not seen a write up with pics. in about 5 years. No one made it a sticky. You could make one and request the moderators to sticky it. Some one did a 06 4.2 swap about 6 months ago but did not do a tutorial. It's pretty easy so most people who know hot to do this do not want to stop, wash their hands, and take pics.
Many people ask about this project and 2% of the people who ask do it. You only gain 10 hp and 35 tq with the Windstar intake. The 3.8 intake blocks a lot of air and lowers your numbers.
Old 06-16-2014, 12:23 PM   #10
lemons95's Avatar
The torque is really noticeable compared to a stock 3.8, a 1994-98 v6 is suppose to make a 145 HP at 4500rpm, and 215 torque 2500.
When I dynoed mine I got 210tq at 2000 rpms and 110hp at 4000rpms.
With just the 4.2, with my 94-98 heads. I was running mid-high 16's. With a 8.8 swap with 3.27's and a CAI I dropped down to mid 15's in the quarter mile.
There should/was a 4.2 sticky on this forum, it's what I used mostly.
Old 06-16-2014, 06:01 PM   #11
well the best thing for me to do then is to just pick up this long block, and swap all my stuff over onto it for now then proceed to have it tuned once up and running. so im thinking this '99 long block will work. will my mustang upper intake bolt to the f150 lower?
Old 06-16-2014, 07:46 PM   #12
lemons95's Avatar
I don't see why you would need a f150 lower, unless they changed the heads.
I thought all the split port heads and intakes were the same, except for the windstars, their always different.
Old 06-16-2014, 09:42 PM   #13
ok thanks everyone i think ive got all my info straight forward on the 4.2 swap now. one last question for the guys with manual transmissions. can the engine be pulled without removing the t5?
Old 06-17-2014, 10:08 AM   #14
I thought the f-150 lower intake was like the Windstar intake. I went to Autozone.com and the gasket is the same as a Mustang.
I have seen a bunch of 98 f-150s and you do not have to take the upper intake off to remove the motor. Taking the trans. out with the motor would make it harder.
Remember to remove the motor mounts before stabbing the engine into the trans. when installing.
Old 06-18-2014, 07:56 AM   #15
In my experience, pulling the the motor and trans out as one assembly is easier and its a much easier re-install too. Get a load leveler with your cherry picker, have the hood off and someone to help you guide out the whole shebang. Swapping the trans while the motor is hanging on the picker is child's play also compared to wrestling with it with the engine in the car.
Old 06-21-2014, 09:12 PM   #16
does anyone know the best way to get to the top bellhousing bolts on the 3.8 without pulling the t5 transmission from the car? do i need to pull the upper intake of or is there a way to get to it from the bottom?
Old 06-22-2014, 02:36 AM   #17
lemons95's Avatar
Your going to need the intake off anyways. Why not do it now?
Old 06-22-2014, 07:27 AM   #18
Why not just pull it all at once? It would probably have been out already since its all of 2 nuts on the crossmember and a few electrical plugs.
Sent from my VS980 4G using Mustang Evolution mobile app
Old 06-22-2014, 06:07 PM   #19
well, after lots of frustration its finally out. i pulled it all together, not really what i was aiming for but oh well, the 4.2 is being dropped off on friday, when i will start swapping everything over, i know i need a new oil pan, my question is would my oil pickup tube and screen still be good even tho the engine tossed a rod?
Old 06-22-2014, 08:07 PM   #20
lemons95's Avatar
Clean them out as best as possible, might be some metal shavings in it.
Unless your oil pan is damaged I think you can use it.
I kept my oil pan.
---------- Post added at 09:07 PM ---------- Previous post was at 09:07 PM ----------
I kept my oil pan.
Old 06-23-2014, 12:20 PM   #21
It depends on which piston broke and did it go through the oil pan? Break cleaner will get the metal shavings off the parts.
Old 06-23-2014, 03:57 PM   #22
ya oil pan is toast big hole in the drivers side of it.
7.5 to 8.8 rearend swap questions... strawdog Pre-2005 V6 Mustang 6 06-18-2009 03:11 PM
swap questions ryanxup Pre-2005 V6 Mustang 10 01-27-2007 11:02 AM
I have a couple 5.0 swap questions colinsv6stang 1979-1995 Mustang GT 5 04-28-2006 12:18 PM
Gear and axle swap questions. DarkShadow Pre-2005 V6 Mustang 15 09-07-2005 02:18 AM
Yup, more v6 to 4.6 swap questions fast64 1996-2004 Mustang GT 10 06-19-2005 01:30 PM
04:43 AM
