loud noise help!!! - Mustang Evolution
Old 06-20-2014, 02:29 AM   #1
Region: West Virgina
loud noise help!!!
Okay over the past couple days ive been messing with my mustang. I notice the intake manifold had a lot of carbon build up and so did the intake plenum. I removed both cleaner them and cleaned the valve cover and replaced the gaskets. I replaced the spark plug wires and spark plugs and coil pack. Ever since ive done so theres this loud noise coming from the Throttle Body like LOUD. someone told me to replace the IAC valve which I did but it still does the noise. Any know why its doing this please help.!!!
v6powerstang is offline   Reply With Quote
Old 06-20-2014, 02:38 AM   #2
bucko's Avatar
Backfire from having a plug wire reversed with another?
Old 06-20-2014, 02:49 AM   #3
Bucko what noise does back firing make?
Old 06-20-2014, 02:52 AM   #4
bucko's Avatar
Could be a bang or poping noise. The idle and/or performance should be altered as well if a pair of plug witres were reversed, as two cylinders would not be providing any power.
To check, google "firing order for a Ford <enter your year and engine size here>"
This should net you a site that has a picture of the engine, marking its plugs and firing order. Pre 2005's have one coil pack, correct? Not sepereate coils (CAP) per cylinder? If each cylinder has its own CAP, then one of those may be bad, and you should have a code (CEL) stored for it.
Old 06-20-2014, 06:20 AM   #5
Yeah, check that. In my case I thought each side of the firing order was in order like 1-2-3, 4-5-6, but it was actually 5-6-4 or something
"Joey" 2004 v6: SR CAI, MPT Tuned, 4.10 gears
Miri is offline   Reply With Quote
96 mustang making loud screeching noise from engine.. HELP! Justin96 1996-2004 Mustang GT 1 02-08-2013 05:51 PM
Loud Noise in Mach 460 system - HELP!! Jason72 1996-2004 Mustang GT 0 06-28-2012 12:25 PM
loud grinding noise! roach 1996-2004 Mustang GT 13 03-24-2008 10:01 AM
loud creeking noise roach 1996-2004 Mustang GT 8 09-25-2007 09:14 PM
loud engine noise. need help!! tealstangman Pre-2005 V6 Mustang 22 01-15-2004 06:57 PM
01:32 AM
