How wide of tires - Mustang Evolution
Old 06-21-2014, 09:08 AM   #1
2000v6stang's Avatar
Region: Iowa
How wide of tires
I have the 16 inch 5 spoke rims on my mustang with 215/60R16 tires on it I am getting new tires in a few days and I wanna know how wide I can go on these rims when looking up my car on tire sights it brings up 215 and 225 so I was hoping I could do at least 235. And for the biggest I can go what should my aspect ratio be.
P.S. I don't know if this will change anything the original rims on my car were the 15 inch 6 spoke rims they had 205s on them I don't know the aspect ratio but they were Kelly charger GTs
Blacking it out, MAC duel exhaust, SR CAI, Performance Automatic shift kit. And a long build list wrecked in July '14
2000v6stang is offline   Reply With Quote
Old 06-21-2014, 12:27 PM   #2
I would go with 255/55/16's. That will give you a wider tire, slightly less sidewall and you won't rub your sway bar at full lock.
Old 06-21-2014, 04:07 PM   #3
Region: Iowa
OK so that wouldn't mess with my wheel speed sensor to much or at all?
Old 06-21-2014, 04:29 PM   #4
I don't believe so as the factory 16" 5 spokes came with Goodyear Eagle 255/55/R16's.
I still have them on my factory 5 spoke wheels and they never had any problems, speedo was dead on as well.
Old 06-21-2014, 06:48 PM   #5
Region: Iowa
thank you again!! now I wont have tires that look like they came off of a prius lol
Old 06-21-2014, 07:01 PM   #6
Region: Iowa
on tire rack Hercules goodyear and hankook I cant find any tires in that size
Old 06-21-2014, 08:30 PM   #7
I just re-read my recent posts, I made an error. I meant to say 225/55/16, not 255's.
255's will be too wide on that size rim. Try for 225/55/R16's.
Old 06-21-2014, 08:55 PM   #8
Oh2freshstang's Avatar
How wide of a tire u can fit depends on how wide your wheels are!
Old 06-21-2014, 09:21 PM   #9
Fitment matters of the size of the wheel and also where you are putting it. No more than a 275 up front without an SLA front suspension conversion. You can put nearly anything in the back.
Old 06-22-2014, 10:40 AM   #10
Region: Iowa
ahhh I see I was thinking that was pretty wide so that would be the widest I should try on the rims I have
Old 06-22-2014, 07:56 PM   #11
You could probably get away with a 235 but I wouldn't go much wider.
Try this tire size calculator:
Tire Size Calculator - Tire & Wheel Plus Sizing
Old 06-22-2014, 09:04 PM   #12
Region: Iowa
okay thanks man!
Old 06-22-2014, 10:21 PM   #13
Region: Iowa
Tire rack said optional rear tire size 245/50/16 and on the tire calculator its only 0.6% off what do you think of that or should I just stay with 225/55s or 235/55s
Old 06-22-2014, 11:27 PM   #14
DaBluedude's Avatar
I would stick with factory specs or maybe a tiny bit wider. To go with wider rubber, you should invest in a wider rim.
2003 Mach 1
Old 06-23-2014, 06:22 AM   #15
Region: Iowa
ok thanks ill stick with 225s or 235s
Old 06-23-2014, 08:15 PM   #16
Not having checked I would guess that 225's would be noticeably cheaper than 240's...
Either way I'd stick with 225's or the 235's as the widest option. As mentioned above a wider tires truly warrant wider wheels.
Old 06-24-2014, 08:49 PM   #17
Region: Iowa
ok thank you man
Stock tires on 10in wide rims mustangtuner Mustang Wheels & Tires 8 09-22-2013 02:41 PM
wide tires/wheels? lemons95 Pre-2005 V6 Mustang 4 02-23-2012 02:44 AM
Wide tires Sambrostang Mustang Wheels & Tires 5 01-19-2012 08:07 PM
how wide of tires 96mustangv8 1996-2004 Mustang GT 30 05-07-2011 04:53 AM
pro's / con's on wide tires Exit_In_Red Mustang Wheels & Tires 7 03-20-2005 11:01 PM
09:56 PM
