Mustang misses, smoking and, getting horrible mpg - Mustang Evolution
Old 06-22-2014, 11:13 PM   #1
tdye369's Avatar
I have an 00 mustang v6 and when i start it up it starts to smoke (it takes like 30 seconds to start) a little but when I get it going it stops smoking and it sounds like it's missing a little on the passenger side of the engine and some times it stalls when I put my foot to the floor it's also been getting horrible mpg like 150 miles to the tank any advice would be great
tdye369 is offline   Reply With Quote
Old 06-23-2014, 07:41 AM   #2
Iryan7's Avatar
Have you checked your spark plugs and wires? If they seem fine, check your firing order.
Name:   ImageUploadedByMustang Evolution1403530914.303474.jpg
Iryan7 is offline   Reply With Quote
Old 06-23-2014, 08:52 AM   #3
Replace your ignition coil and see if that works. The motorcraft ones at auto stores are $100
"Joey" 2004 v6: SR CAI, MPT Tuned, 4.10 gears
Miri is offline   Reply With Quote
Old 06-23-2014, 09:31 AM   #4
Iryan7's Avatar
Start small, then get bigger. Try checking your firing order. If that's not it, replace your spark spark plugs, then wires, and then the coil if it's still not fixed. Spark plugs are about $30 for 6, depending on where you're at. I recommend motocraft.
P.S. You will have to remove the air intake to change the passenger side spark plugs. It's not hard, and there are many YouTube videos on it. Get a small ratchet and maybe even a swivel spark plug socket. It'll make things easier. Good luck!
Old 06-23-2014, 11:00 AM   #5
tdye369's Avatar
People have told me maybe it's the fuel regulator too but the person I got it from changed the wires but not the plugs
Old 06-23-2014, 03:23 PM   #6
tdye369's Avatar
The mechanic in my town said the coolant temp gauge throws a bunch of stuff and could be what is giving me bad gas mileage any ideas?
Old 06-23-2014, 05:46 PM   #7
tdye369's Avatar
I just changed the plug wires the plugs and the ignition coil and it's still running the same
Old 06-23-2014, 08:41 PM   #8
fwalck's Avatar
What color is the smoke if its white it means coolant is getting into your cylinders and it could be there when you first start it and then go away and that could also cause a miss.
fwalck is offline   Reply With Quote
Old 06-23-2014, 08:43 PM   #9
tdye369's Avatar
The smoke is kind of a whitish blueish color
Old 06-23-2014, 08:44 PM   #10
tdye369's Avatar
I changed my spark plugs today and they had oil on some of them is that just the valve cover leaking?
Old 06-23-2014, 10:27 PM   #11
Iryan7's Avatar
It could be, if it's on the boot part. If it's in the rings, then you might have more problems, a bent piston or broken rings to name a few.
Old 06-23-2014, 10:29 PM   #12
Iryan7's Avatar
How many plugs had oil on them?
Old 06-23-2014, 10:31 PM   #13
tdye369's Avatar
I'm gonna change the efi pressure regulator next and if not that then I'm gonna do the injectors
Old 06-24-2014, 05:49 PM   #14
fwalck's Avatar
I would do a compression test to check everything out if you have low compression pour a little oil down into the cylinder to see if that helps raise the compression
Old 06-24-2014, 06:46 PM   #15
fwalck's Avatar
Old 06-27-2014, 08:39 PM   #16
V6 stang's Avatar
Whiteish blue typically means blown head gasket.
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 06-27-2014, 08:40 PM   #17
tdye369's Avatar
But it runs and drives good just sucks to start and idle
Old 06-27-2014, 09:22 PM   #18
fwalck's Avatar
I would get a compression test done it sounds like a head gasket
Old 06-27-2014, 09:25 PM   #19
V6 stang's Avatar
It may not be extreme yet. Run a compression test. Have you checked your coolant levels? Keep a close eye on it. You have symptoms of a blown/leaking head gasket.
Roush Exhaust
Old 06-28-2014, 08:39 PM   #20
fwalck's Avatar
You could always take it to a shop with a 5 gas analyzer and have them check your coolant for hydrocarbons to know for sure.
05-09 GT mpg vs 99-04 GT mpg GP3GT 2005-2010 Mustang GT 10 05-03-2013 03:08 PM
v6 horrible mpg and preformance tommygrubb2001 Pre-2005 V6 Mustang 31 02-22-2013 04:19 PM
What kinda mpg yall getting? Speed_Mister 1996-2004 Mustang GT 21 09-03-2012 10:07 PM
misses once warm foxneedswork 1979-1995 Mustang GT 15 08-20-2012 12:15 PM
MPG-MPG insidious_ruin 2011-2014 Mustang GT 26 07-19-2012 07:18 AM
05:02 PM
