Loud screeching noise when I turn left?? - Mustang Evolution
Old 06-24-2014, 07:43 AM   #1
Stang_life3's Avatar
So I've recently heard a loud screeching noise coming from my front end. I only hear it when I turn left, go over speed bumps, and accelerate from a dead stop. It's not my power steering because I put the front end on jacks and turned the wheel around but there was no noise. I jerked the wheels around and spun them while I had it up but nothing. I'm starting to think it's a bad tie rod. Any other suggestions? It's a 1999 3.8 auto
Stang_life3 is offline   Reply With Quote
Old 06-28-2014, 07:58 AM   #2
Sluder4's Avatar
Mine did the same thing cause it needed to be aligned and after I got it aligned it stopped.
1999 V6 Mustang Dark Satin Green , SR CAI, BBK 65mm Throttle Body, Screaming Demon Coil Pack, SR Lowering Springs, Pioneer Stereo, 2 12' inch subs and 1600watt amp, Green Calipers,
Sluder4 is offline   Reply With Quote
Old 07-24-2014, 06:27 PM   #3
Sketchificus's Avatar
Definitely check your ball joints dude. My car used to make the most awful screech when turning, hitting bumps and the like. Although I haven't had them changed, the noise is still there but very subtle
Sent from my XT1080 using Mustang Evolution mobile app
Sketchificus is offline   Reply With Quote
Old 07-28-2014, 03:08 PM   #4
I still haven't figured out what it is. I got the front ball joints on both sides replaced but still no luck. I drove it to the beach which is about 3 hours from where I live. The whole way there it mad the noise. On the way back it didn't make the noise at all and for about a week it didn't make any noise. Then all of a sudden it came back about 2 days ago. I have no clue what it is.
Old 07-28-2014, 04:06 PM   #5
Hmm. Well it's definitely got something to do with suspension components. Maybe some bushings somewhere in the front? Sway bar? Idk I thought for sure it'd be ball joints dude
Old 07-28-2014, 04:20 PM   #6
I'm pretty sure it's coming from the rear. Now that it has been making the noise for a while it sounds worse. It's definitely coming from the rear and it's not only when I turn left now. It makes the noise the worst when I begin rolling forward at a stop light and when I turn left in parking lots. When I get above 40 it doesn't make any noise until I slow it down.
Old 01-31-2015, 07:12 PM   #7
Sounds like hub or axel bearings
Have you checked either?
tsteevs_foxbody is offline   Reply With Quote
Old 02-05-2015, 04:44 AM   #8
Jaytraeg's Avatar
Might be a bad brake pad that's rubbing. When's the last time you had brake work done? Otherwise I know from experience that bad tie rods can do that too, but it sounds like you already replaced those.
Jaytraeg is offline   Reply With Quote
Old 02-05-2015, 09:30 AM   #9
Darth Paul's Avatar
Don't turn left
Sent from somewhere near the center of the Milky Way
Darth Paul is offline   Reply With Quote
What is the screeching noise coming from my front end??? Stang_life3 Pre-2005 V6 Mustang 0 06-23-2014 05:22 PM
What is the screeching noise coming from my front end??? Stang_life3 General Mustang Discussion 0 06-23-2014 11:36 AM
Air condition making loud noise when i turn it on Shark3y 1996-2004 Mustang GT 2 07-29-2013 06:34 PM
96 mustang making loud screeching noise from engine.. HELP! Justin96 1996-2004 Mustang GT 1 02-08-2013 05:51 PM
screeching noise vinnygt 1996-2004 Mustang GT 27 07-08-2011 10:14 AM
10:41 PM
