Polishing intake manifold - Mustang Evolution
Old 06-24-2014, 10:51 PM   #1
2000v6stang's Avatar
Region: Iowa
I just took my intake manifold off of my car I want to polish it in and out. Is polishing a good idea ive head it said that it my not let the fuel air mixture mix as well I just need some opinions and facts about it. Good idea or no? How is it done?
Blacking it out, MAC duel exhaust, SR CAI, Performance Automatic shift kit. And a long build list wrecked in July '14
2000v6stang is offline   Reply With Quote
Old 07-03-2014, 12:31 PM   #2
baddbradd's Avatar
fuel only flows thru the last couple of inches of your lower intake.
2001 coupe
baddbradd is offline   Reply With Quote
Old 07-04-2014, 11:15 PM   #3
samuelsmith's Avatar
At the bottom of the lower intake you have to worry about poor atomization. Poor atomization also produces an engine that does not run well, since the mixture entering the cylinders varies on each bore and cycle. This potentially creates an unstable idle, tip-in hesitation, and a general lack of performance, along with a higher rate of fuel consumption. Thus, it's very important for the fuel to be completely atomized. For the engine to perform as designed, the maximum possible chemical-to-mechanical energy conversion must occur.
I can tell you how to port the upper intake if you are interested? It is only worth 3 hp. unless the intake is cut open polished and welded back together. If you do the lower intake also YOU WILL GAIN 8-10 HP.
Old 07-10-2014, 07:29 PM   #4
Region: Iowa
would it be better to do a windstar intake. The thing with the engine im doing it on is I bought it its out of a 99 v6 so im just taking it apart and doing small stuff to it for now till after college then im going to rebuild it and build it up so would it be better to do a port an polish or just find out more about converting to a windstar intake
Old 07-11-2014, 12:35 PM   #5
The Windstar is better. You will gain 7 hp. n 15 tq. You should ask Pancho about the swap.
port polishing heads and intake manifold jeMstang General Mustang Discussion 12 02-04-2014 10:53 AM
Boss intake manifold and the stock intake Yellow50 2011-2014 Mustang GT 43 04-26-2012 06:30 AM
Intake Manifold vs Intake Man-child jbanks 1996-2004 Mustang GT 17 08-02-2011 04:55 AM
Polishing Help Black95GT Mustang Audio & Video 8 09-29-2004 11:59 AM
Polishing my new Lower Intake from RPM Danger Dude Pre-2005 V6 Mustang 3 03-01-2004 11:15 AM
07:22 AM
