spring problems, 1st post - Mustang Evolution
Old 12-06-2003, 09:44 PM   #1
Put Eibach pro kit springs on my car (2001 mustang). The front dropped like it's supposed to but the back didn't. It's sitting noticably higher. I took it to 3 different shops and they all said it's the springs. It doesnt look like Eibach or the place I got them from is going to do anything for me, so my question is could i cut the dead coil on the rear springs or remove the spring isolators to get another quarter to half inch drop. Will it do any damage to the car? Thanks in advance for any help.
fb305 is offline   Reply With Quote
Old 12-06-2003, 09:59 PM   #2
It raised your rear??? Wow never heard about that. SpectorV could probably give you some advice on cutting the rears.
Old 12-06-2003, 10:09 PM   #3
Sorry I worded that bad, It didn't raise the rear, it's just didn't drop it very much, so now the rear is noticably higher than the front. Just want it to look more even with the front.
Old 12-06-2003, 10:19 PM   #4
ah got you.... the rear springs dont lower as much as the front. But it shouldnt be as bad as you say yours is. Do you have a side picture of your car with the springs and without them?
Old 12-06-2003, 10:21 PM   #5
I have the same problem with the Steeda sport springs. Steeda are made by Eibach... So who would have guessed? I'd wait for them to settle and see if that helps.. I recommend against removing the isolators unless you like a really noisy ride.
Laser02 is offline   Reply With Quote
Old 12-06-2003, 10:28 PM   #6
Dont have a side picture to post but it's definately not low enough in the back. I also have talked with the tech guy at eibach and he says they probably wont settle any more than they are. The guys at one of the shops I took it to said they've had the same thing happen to a couple other cars with eibach springs too.
Old 12-06-2003, 10:30 PM   #7
Yeah. My rear springs seemed about the same height as the settled stock springs... I don't know if you should cut the coil or not, but removing the isolators would suck on a daily driver.
Old 12-06-2003, 10:38 PM   #8
Same with mine, It dropped a little but not enough. The eibach tech guy is acting like this never happens. I'm trying to get them to send me new rear springs, I'll fight with them more on monday. Decided against losing the spring isolators, I read a couple other threads, sounds like a bad idea.
Old 12-06-2003, 10:44 PM   #9
crap guess what springs are sitting right next to me... waiting for my new car... Eibach.... lol
O well. Maybe they will fit better on pre99
Old 12-06-2003, 10:47 PM   #10
Didn't mean to scare you Brent! I don't think this happens that often, but of course it would happen to me!
Old 12-06-2003, 10:49 PM   #11
yea I have about the same luck
Old 12-07-2003, 12:34 PM   #12
Danger Dude's Avatar
I am not a big fan of Eibach. not they are not good springs but seem to have more problems than most. Most Eibach springs are not designed to cut unless they say you can. Here are 2 big problems I see with eibach
A. They cater to imports
B. In my reading on all the different boards I have read many post about the inconsistancies and lack of Quality Control of their product.
Old 12-07-2003, 05:23 PM   #13
My springs were like 1/8th" shorter than the stock ones.. If that. I figured they'd settle a bit.. But, if not.. Well. I don't really care. At least it's not the other way around. Nose-down stance is alright with me. Maybe they just wanted us to put bigger tires in the back...
Old 12-08-2003, 08:23 AM   #14
go measure your drop front from ground to top of fender (the under side edge of the wheel well) and from the rear the same way, stock is 28.25 inches front and rear~ I am sitting at 27.0 front and 27.5 rear with my c springs with HALF a coil cut on the rear, its probably not a good idea to cut the eibachs, but if you had to cut one, the rears would be the best set to cut... I am not gonna say cut em but you can.... I would call eibach and see what they have to say about it, you have to make sure your pig tails are facing right, jack it up and take a look they should be facing back or to the passenger side, the farther you rotate yoru coil so that the inner part of the spring away from the pig tail is sitting on the perch the lower the car will be, but you can only rotate the spring so much before it goes all the way around and the pig tail is back on the perch lol, just turn the spring sot hat the pig tails are facing the SAME Way and probably toward the passenger side for maximum drop on those springs. you cut the top of the rears if you do any cutting.
getting the springs out is super easy, jack up car, take off wheels, unbolt shocks AFTER putting jack under pumpking and jacking up rear end (rear end being the axle) then drop rear and place jack under one of the ends (under an LCA will do great) and jack up this will force the other end downa dn you can get the spring out super easy, then repeat for the other side and get the other spring out...
only 2 bolts need to be removed. if you cut ONLy cut half a coil and see how it looks, but you really sould measure first and see how much of a height difference you are dealing with, and make sure you dont go do it out in the YARD get on a freaking flat surface lol a for SURE flat surface.
Old 12-08-2003, 08:35 AM   #15
Monkey's Avatar
dont forget they are really soft springs too and dont give much (if any) suspension gain on our cars
Old 12-08-2003, 06:11 PM   #16
Hm, ha damn Eibachs. I got the exact opposite problem. Fronts didnt get disired drop but back is fine. Believe it or not they did settle about 1/4 an inch out back for me.
Im sitting at just under 27.5, I guess 27 3/8. Front for me is 27.5, not low enough in my opinion.
Thanks SpectorV, thats an excellent idea for the fronts I had not even thought of, damn shop install
I hate not doing stuff myself
Joer.
'98 Cobra Rims, 245/45 Dunlops, Mach1 Chin Spoiler, GT Takeoff Swaybar, Eibach Pro Kit, 20% Tint, eBay Cold Air intake, Kenwood 4022 Headunit, Tri-ax shifter, True Dual Exhuast w/ Spintech Pro Streets
JoeR. is offline   Reply With Quote
Old 12-08-2003, 10:03 PM   #17
Thanks for the info spectorv, I asked the eibach tech guy about turning the springs like you said and he said that should lower it some, so i'm gonna try that. He said the only way eibach would replace them was for me to send them back where I got them, have them send them to eibach and then they would test them to see if they meet their specs, if they don't then they would replace them, if they do they just send them back, said they would have them for 2 to 3 weeks to test them. I told him if I couldn't get them to look right by turning or cutting I was gonna pull them out and trash them, and then buy ford-c springs.
Old 12-10-2003, 07:13 AM   #18
That is true Brandon. the fact is I have a friend that put Eibach's on his Civic and it bounces to much. He has to slow down when going over little pothole or uneven road or he will bottom out. He changed back to the stock springs
Old 12-10-2003, 08:17 AM   #19
Rick0636's Avatar
Hey now, I have a used set of Eibachs on my GT and they are fine! I don't have a complaint with them really. I do think the Steedas I took off the front might have been a bit stiffer though, and I am going to try a set of Eibach Cobra R front springs on it soon too.
Old 12-11-2003, 11:11 PM   #20
Send a message via AIM to ASSEMbler
So if not eibachs, then what brand would settle right?
SIG REMOVED FOR THE PRUDE
ASSEMbler is offline   Reply With Quote
Old 12-11-2003, 11:16 PM   #21
Rick0636's Avatar
Why don't you look at H&R Race Springs? Or maybe Super Sports?
Old 12-13-2003, 02:17 PM   #22
Dom
Dom's Avatar
Send a message via AIM to Dom
I would say heat the rear springs up, but that may not be the best idea for you.
Old 12-14-2003, 06:34 AM   #23
Send a message via AIM to ExBamaGal Send a message via Yahoo to ExBamaGal
I have the Eibach Pro-Kit and have no problems
http://ml.truckmoxie.com/mygallery.asp?id=3869
ExBamaGal is offline   Reply With Quote
Old 12-14-2003, 12:33 PM   #24
Dom
Dom's Avatar
Is it possible they threw in the wrong rear springs? Like from another car or something?
Old 12-15-2003, 08:22 AM   #25
that usually because import guys buy springs and not new dampers. Thus, having an inconsistancy in suspension and crappy ride.
Eibachs aren't import springs, thats the funniest thing I've ever heard. The 95 Cobra R used Eibach Road Race springs, some import company eh?
I think the only problem with eibach is that their ride heights aren't what they advertise. Other than that they are quality springs.
If you do change out your springs, try some H&R's.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 01-04-2004, 08:26 PM   #26
Send a message via Yahoo to ndotym
I'm running the MRT kit, matching shocks and springs 1 1/4 even all the around...I tried steedas a little rough...
ndotym is offline   Reply With Quote
Old 01-04-2004, 08:35 PM   #27
Dom
Dom's Avatar
Goes to show you, that generally the best way to go is upgrade the main compnents in a suspension system.
Old 01-04-2004, 10:02 PM   #28
Rick0636's Avatar
Not saying they aren't good, but never heard of mrt suspension??? Steeda is generally very good stuff their springs are made by Eibach and considered to be better than Eibachs due to steeda's specs being better than Eibach's own.
It is almost always better to upgrade your struts and shocks when you change your springs though.
Old 01-04-2004, 10:43 PM   #29
BlueDonkey's Avatar
Rick, I believe ndotym means this: http://www.mustangracing.com/
BlueDonkey is offline   Reply With Quote
trans problems 1st to 2nd automatic 96 cobra vert 1996-2004 Mustang GT 14 10-19-2007 01:41 PM
Site upgrade, post any problems here Brent ME Site Help & Announcements 0 01-04-2006 04:55 PM
stock spring spring Scut95 1979-1995 Mustang GT 2 09-15-2005 04:11 PM
Problems with forum? Post here Brent The Bar 72 08-04-2005 09:50 AM
Post any errors or problems that you have with the forum! Brent The Bar 27 07-26-2003 06:08 PM
03:55 AM
