99-04 door jamb switch location - Mustang Evolution
Old 06-28-2014, 03:59 PM   #1
OfficialMakkyZ's Avatar
I have a 2000 and I need to replace the door jamb switch and can't find it on the car. Can anyone tell me where it's located?
MakkyZ
2000 v6, Decepticon themed.
Plastidipper. Customizer. Modder.
Check out my garage:
http://www.mustangevolution.com/forum/f376/t351203/
OfficialMakkyZ is offline   Reply With Quote
Old 06-30-2014, 08:24 AM   #2
Bump, someone help!
MakkyZ
Old 07-02-2014, 09:14 AM   #3
samuelsmith's Avatar
It's in the door on the latch
Old 07-02-2014, 03:11 PM   #4
Like, where on the latch? I took the door panel off and saw the latch assembly inside the door, but how do I get to the door switch?
MakkyZ
Old 07-02-2014, 10:04 PM   #5
It's built into the door locks and looks like this. Ford Door Lock Actuator Pair Left Right New | eBay It does not look like the old push pin.
Old 07-03-2014, 08:46 AM   #6
Hmm.. This is the part they have me at autozone for it. Is it right?
MakkyZ
Old 07-03-2014, 09:04 AM   #7
I guess it is I am more than likely wrong so I did some searching. This is the only answer I could come up with. _______We are back in Reno, drove this 99 Ford Mustang here and fixed the door ajar switch problem after reading the 1999 Ford Mustang Workshop Manual, Volume two.
The Ford Mustang door switch connects to the door latch assembly---cannot be seen without taking the door apart.
I guess it is underneath the latch I showed you.
Old 07-03-2014, 12:46 PM   #8
Crap. Any tips on taking that inner metal door panel off? I haven't even looked at it really
MakkyZ
Old 07-03-2014, 01:10 PM   #9
From the way I understand it. The door pin is behind the actuator. It should unscrew. The actuators in the center at the rear of the door. It will be hard to get to but not impossible. You will need a flashlight.
Old 07-03-2014, 01:20 PM   #10
MakkyZ
Old 07-04-2014, 10:38 AM   #11
The metal is welded together. The door panel will come off.
Old 07-04-2014, 02:12 PM   #12
How do I get to the switch then? Lol
MakkyZ
Old 07-04-2014, 11:03 PM   #13
Do you know how to get the first door panel off, not the metal one?
Old 07-07-2014, 07:43 AM   #14
Yessir. Don't know where to go from there.
MakkyZ
Old 07-07-2014, 07:18 PM   #15
mustang 1999 2004 door jamb switch - Bing Videos
This video gives you a idea of how to do it and where the jamb switch is located. Instead of reaching through the door handle and doing everything. you are going to need a flash light and have to reach in from the inside of the door.
Old 07-08-2014, 12:43 PM   #16
It's just a video search, not an actual video lol
MakkyZ
Door jamb is different color than car escottcarp Mustang Paint, Appearance & Detailing 2 01-29-2014 07:55 PM
HELP Door jamb transmission TR code 2000v6stang Pre-2005 V6 Mustang 3 09-14-2013 02:59 PM
Need help locating door jamb light switch 302horses Pre-2005 V6 Mustang 2 03-17-2011 05:17 PM
Valet switch?? Location? Viper chris7869 Pre-2005 V6 Mustang 6 02-11-2008 01:12 PM
Location Location Location Ken The Bar 9 08-07-2003 08:51 AM
» Members Mustangs
Candy
OneBad3.7
Rosco
Rosco
Add your Mustang
05:51 PM
