3.8L Mustang Clutch adjustment? - Mustang Evolution
Old 06-29-2014, 11:23 AM   #1
Just wondering everytime I pull away in my 02 mustang or shift gears and let out the clutch the pedal seems really loose and it starts " tapping " its getting worse now before you could just feel it on your foot.. im wondering if this could be cause a stretched cable. is there anyway to adjust it to hold me over until I order a new cable and quard.. thanks john
Jawny is offline   Reply With Quote
Old 06-29-2014, 07:14 PM   #2
Markos's Avatar
Region: Iowa
Mine been "purring" for over two years and I havent had any problems
Sent from my SCH-R530U using Mustang Evolution mobile app
Markos is offline   Reply With Quote
Old 06-30-2014, 06:14 PM   #3
Bravebowhunter's Avatar
Sounds more like the throw out bearing it will make some noise when your off the clutch and you can feel it in the pedal
1967 coupe 351w 5 speed dual exhaust, 2000 v6 5 speed dual exhaust, 2005 ford ranger single cab 3.0 auto
Bravebowhunter is offline   Reply With Quote
Old 07-02-2014, 09:18 AM   #4
samuelsmith's Avatar
To adjust the clutch cable you must put your foot under the clutch petal and pull up.
Clutch Pedal Height Adjustment and Clutch Freeplay Mod ab_mach1 1996-2004 Mustang GT 126 10-20-2017 03:21 AM
Clutch adjustment cmduffy33 2005-2010 V6 Mustang 1 08-29-2011 08:21 AM
RAM clutch cable adjustment on 99 cobra nasty99 1996-2004 Mustang GT 2 06-01-2011 01:56 PM
Clutch adjustment eddie1 1996-2004 Mustang GT 8 05-05-2009 07:31 AM
Clutch adjustment (2001 stang) cagedthought Pre-2005 V6 Mustang 7 03-27-2005 09:49 AM
06:23 PM
