Idle issues - Mustang Evolution
Old 07-03-2014, 01:12 PM   #1
rodgersc77's Avatar
Idle issues
Hey,
When I stop my car drops in rpm's to around 500 and feels like the car is going to die then goes back up to around 1,000 rpm's and continues to go back and forth till I start driving again.
Thank for any help!
rodgersc77 is offline   Reply With Quote
Old 07-03-2014, 07:19 PM   #2
IWstangboy03v6's Avatar
Check your egr valve, sensors and hoses going to and from everything
Sent from my XT1080 using Mustang Evolution mobile app
IWstangboy03v6 is offline   Reply With Quote
Old 07-03-2014, 08:34 PM   #3
Mine sits at 500 rpm when idle. I had a fluctuating idle when I needed my ignition coil to be changed
"Joey" 2004 v6: SR CAI, MPT Tuned, 4.10 gears
Miri is offline   Reply With Quote
Old 07-24-2014, 06:22 PM   #4
Sketchificus's Avatar
Hey miri, does your car vibrate really bad when it sits at 500 rpms? I'm assuming you are talking about when you're in D and stopped?
Sketchificus is offline   Reply With Quote
Old 07-24-2014, 06:28 PM   #5
rodgersc77's Avatar
When mine drops to 500 and I'm in drive it vibrates really badly
Old 07-27-2014, 10:25 AM   #6
Air leak in vacuum lines or on air intake. Good place to start looking.
Old 08-07-2014, 10:17 PM   #7
2000v6_Nat's Avatar
Region: Nebraska
My idle is crappy too. Changed out the idle air control with one I found on a junk mustang and fixed it right up.
No engine/performance mods (yet). Mach 460 sound system, 2 12" alpine subwoofers in a custom box w/ 1800watt kenwood amplifier. Smoked halo headlights, smoked sequential taillights, black bullitt staggered rims, racing stripes, and plastidipped spoiler. Future exterior mods - Chin spoiler, black fuel door, and demon fender flares (plastidipped).
2000v6_Nat is offline   Reply With Quote
Old 08-25-2014, 05:50 AM   #8
rodgersc77's Avatar
Any idea what would cause very crappy gas milage? I have new plugs, wires, oil change, air filter, and fuel filter. And I am averaging 15 miles per gallon... I do mostly highway driving and do not drive that hard.
Old 08-25-2014, 06:11 AM   #9
natestang07's Avatar
http://www.ehow.com/about_6157262_sy...e_.html#page=1
Maybe read over that
05 Gt Premium Performance White, flowmaster outlaws
Old 08-25-2014, 06:48 AM   #10
rodgersc77's Avatar
Yeah I was thinking maybe egr. I put a new one in yesterday so I will see shortly I guess.
Old 08-25-2014, 07:29 PM   #11
Get 2 cans of Seafoam. Put one in gas tank, use second sucked through vacuum line or pcv line into intake slowly. Clean the intake & fuel system, it will guaranteed run much better. Cant say it will cure, but it will help. Running much too rich obviously.
Old 08-25-2014, 07:33 PM   #12
rodgersc77's Avatar
Yeah I seafoamed it about a month ago and still had the bad gas milage! I can give it another shot though anything that might help I am willing to try!
Thanks!
Old 08-27-2014, 12:29 PM   #13
Blue Angel's Avatar
Maby ur TPS sensor I had the same prob and it was that or try ur idal controll valve or speed sensor I for got what it was called
Sent from my SPH-L710 using Mustang Evolution mobile app
Blue Angel is offline   Reply With Quote
Old 08-30-2014, 01:46 PM   #14
Hmmm... No MIL's? Reset the computer? Thermostat operating?
Can't remember what causes a rich A/F mixture off the top of my head..
Old 08-30-2014, 02:00 PM   #15
Blue Angel's Avatar
Might help bro
Old 09-03-2014, 07:54 AM   #16
rodgersc77's Avatar
Thanks
Old 10-03-2014, 09:15 AM   #17
SueK's Avatar
How about O2 Sensors? You don't have to get a check engine light for them to be bad. Throttle position sensor or IAC. Cleaning your EGR too. If the idle goes up and down maybe the IAC. Because was like that and at the same time I changed the DPFE4 Sensor. Amazon has them for cheap Amazon.com: Motorcraft DPFE4 Exhaust Gas Recirculation Pressure Feedback Sensor: Automotive
SueK is offline   Reply With Quote
AOD to T5 Swap & Idle, Bucking Issues Trojan Horse 1979-1995 Mustang GT 5 02-06-2012 09:47 AM
Idle issues HELP DHall31 General Mustang Discussion 9 11-23-2011 05:33 PM
Issues at idle iwannagofast 1996-2004 Mustang GT 19 05-09-2011 07:10 PM
You guys with idle issues (possible vacume leak) try this SpectorV Pre-2005 V6 Mustang 3 06-01-2010 01:28 PM
Hot start idle issues Scorpion1 Pre-2005 V6 Mustang 12 04-07-2009 04:58 PM
08:27 AM
