Discovered plugs - Mustang Evolution
Old 07-14-2014, 02:03 PM   #1
PiojoA7x's Avatar
Discovered plugs
I removed my back seat and found 2 plugs. Don't know what they are for. Do any of you guys know? Click image for larger version
Name:	ImageUploadedByMustang Evolution1405368139.679049.jpg
ID:	161463Click image for larger version
Name:	ImageUploadedByMustang Evolution1405368170.338241.jpg
PiojoA7x is offline   Reply With Quote
Old 07-15-2014, 08:34 PM   #2
PRoss.20's Avatar
Region: Arkansas
Are they for the speakers right above the rear seats? I've never had my back seats out so now I'm curious if I have them :p
PRoss.20 is offline   Reply With Quote
Old 07-15-2014, 08:37 PM   #3
The_Chech's Avatar
Back when I had my 98 4Runner I took the carpet out and had plugs like this. Took a few out and some had bolts behind them and some just went straight through and you could see the road.
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 07-15-2014, 09:07 PM   #4
PiojoA7x's Avatar
I don't think they are for the back speakers because these don't have anything plug into them.
Old 07-15-2014, 11:42 PM   #5
samuelsmith's Avatar
Aren't they floor board plugs? Incase you get water in the floor board and need a quick drain. Jeeps have them also.
Old 07-16-2014, 05:18 AM   #6
bucko's Avatar
This could be it....or, they may be used during assembly on the assembly line to access some part underneath.
Pop one out and see if there's a nut, a bolt, or some other fastner right below it.
On the 2011's and up models, the rear seats are removed to gain access to a cover to get at the fuel pump(s) without having to drop the gas tank.
Old 07-16-2014, 10:35 AM   #7
fwalck's Avatar
That's for cars with abs those are for the rear wheel speed sensors the wire would go down where that big rubber plug is
fwalck is offline   Reply With Quote
Old 07-16-2014, 02:03 PM   #8
PiojoA7x's Avatar
I'm guessing the v6 models didn't come with the ABS sensor?
Old 07-16-2014, 04:03 PM   #9
fwalck's Avatar
Some did do you have a traction control button because my 01 had abs
Old 07-16-2014, 06:50 PM   #10
PiojoA7x's Avatar
My does not have the traction control .
Old 07-16-2014, 07:36 PM   #11
fwalck's Avatar
Then you probably don't have abs they put the wiring harness there cause it's probably cheaper and easier to just use one consistent harness vs the how ever many different ones they would need it's just like all cars with out fog lights still have the main harness for them
Just discovered this app. 98GtTurbo New Member Introductions & Greetings 2 08-29-2011 09:39 PM
Discovered some new relays today.. Anyone know what they are for? snipercop 1996-2004 Mustang GT 0 09-26-2009 07:05 PM
I have discovered.....*random warning* bullitt482 The Bar 7 11-11-2007 04:06 PM
We just discovered our 10th planet, Xena, has a moon wiarumas The Bar 9 10-04-2005 08:27 AM
warning: new hazardeous material discovered all over the world fast64 The Bar 5 05-23-2004 05:55 PM
10:19 PM
