Lowering springs - Mustang Evolution
Old 07-15-2014, 08:28 PM   #1
PRoss.20's Avatar
Region: Arkansas
Lowering springs
So I've been looking at lowering springs, and I really want to buy some. However, I have bigger wheels with 245/45/17 tired on and they don't fit completely under the fenders now. I'm wondering if dropping the car with the springs will cause my tires to rub my fender if I hit a big bump or anything like that. Here's a couple older pics so you can kind of see how they are under I guess the lip of the fenders. Let me know if you need better pictures or anything to be able to tell because I really would like some springs. Also, I have a GT rear end will I need GT springs? Are they interchangeable? Or do I need GT springs in the back and not in front?
PRoss.20 is offline   Reply With Quote
Old 07-15-2014, 08:30 PM   #2
PRoss.20's Avatar
Region: Arkansas
Name:	ImageUploadedByMustang Evolution1405477757.218027.jpg
ID:	161556Click image for larger version
Name:	ImageUploadedByMustang Evolution1405477777.937517.jpg
Old 07-15-2014, 09:20 PM   #3
Mile high JDF's Avatar
You'll be fine unless you have some really strange offset on your wheels and you drop the car really low. Any idea how ugh of a drop you want? V6 and GT springs are interchangeable so no issues there.
If you could get some better pictures thay would be great. Does the lip come close like mine does?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 07-15-2014, 09:22 PM   #4
PRoss.20's Avatar
Region: Arkansas
Springs I looked at estimated 1.5" drop. They come a little further out than yours. If they're interchangeable why does AM have spring sets that say they work for GT but not v6?
Old 07-15-2014, 09:35 PM   #5
PRoss.20's Avatar
Region: Arkansas
Lowering springs
A
Old 07-15-2014, 09:59 PM   #6
The GT springs tend to get a stiffer rate in the front to compensate for the heavier engine. You won't rub, I'm an inch lower than you're planing on going and I hardly rub.
Old 07-15-2014, 10:03 PM   #7
PRoss.20's Avatar
Region: Arkansas
Sweet, thank you! I think I might go with the GT so the stiffer springs won't go down as far on bumps. Just to be safe.
Old 07-15-2014, 10:06 PM   #8
Just be warned that the front will sit a little higher than the rear, another member on here named CompOrange has plenty of pictures to prove it. I doubt you're gonna rub though
Lowering springs or factory springs fordracing63857 1979-1995 Mustang GT 3 06-27-2012 08:42 PM
FRPP Lowering Springs - G Springs Stangthang Pre-2005 V6 Mustang 9 02-23-2005 03:57 PM
Bushings for lowering springs Blue232 Pre-2005 V6 Mustang 10 10-09-2003 12:33 PM
Where can i get lowering springs (01' Vert) Stang01 Pre-2005 V6 Mustang 3 09-30-2003 10:44 AM
Lowering Springs -- How Much? Stang01 Pre-2005 V6 Mustang 7 09-20-2003 12:07 PM
09:00 AM
