Transmission max hp - Mustang Evolution
Old 07-16-2014, 03:18 PM   #1
superdrift's Avatar
Transmission max hp
Im wondering what my stock 99 automatic v6 transmission's max hp is and if i would be able to put either a 3.7 or 4.6 engine in it.
superdrift is offline   Reply With Quote
Old 07-16-2014, 03:29 PM   #2
samuelsmith's Avatar
It can handle a 4.6.
Old 07-16-2014, 07:42 PM   #3
mazen123's Avatar
Same exact trans as a GT, it can obviously handle the 4.6. The 3.7 isnt much more powerful than the 4.6 so that should be alright too
mazen123 is offline   Reply With Quote
Old 07-19-2014, 01:07 PM   #4
superdrift's Avatar
Im talking about the 4.6 in a 05-10 gt
Old 07-19-2014, 05:25 PM   #5
mazen123's Avatar
The trans usually handles 50-60 more than stock so yeah you would be ok. The 4.6 (99-04) with the 4r70w supports 260hp at the crank. The 4.6 (05-10) has 300hp-320hp so ull be at the maximum limit of the 4r70w.
Old 07-19-2014, 09:38 PM   #6
Mile high JDF's Avatar
Umm where did you learn this? Then how are supercharged guys with stock transmissions other than a convertor able to put down the 400whp range no problem?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 07-19-2014, 09:47 PM   #7
Lol, the Marauder guys routinely run the 4R70w to 500 ft lbs in a 4k+lb car. So no. The stock auto in the 04 GT/Mach (4R75w) is good for even more.
As for the original poster. Your 99 V6 trans is a completely different bolt pattern than a modular engine so no it won't work just because it won't physically fit.
Old 07-19-2014, 09:47 PM   #8
mazen123's Avatar
I've always learned that to play it safe with the 4r70w, dont go about 50-60 rwhp over stock. Maybe those guys are use the 5 speed T45?
Old 07-19-2014, 09:51 PM   #9
I'll just quote Scotty for you
Old 07-19-2014, 09:52 PM   #10
Marauders are automatics dude. Whoever told you to stick 50-60hp over stock with the 4R either was clueless or was stuck in the 80s/early 90s where domestic automatics grenaded if you sneezed on them. The 4R is good for around 500ft lbs at the tires and the 04s I mentioned are stronger than that.
Old 07-19-2014, 09:54 PM   #11
mazen123's Avatar
Really? Wow lol. That makes me feel better about my car then lol
Old 07-19-2014, 09:57 PM   #12
Just make sure you do fresh fluid in the trans and converter every 30k or so and J-mod the trans if you haven't already. That not only is a practically free "shift kit" but it improves transmission longevity as well.
Old 07-19-2014, 09:58 PM   #13
mazen123's Avatar
How is it practically free? Dont you have to buy j mod kits in order to do so? Or is there a way around that
Old 07-19-2014, 10:02 PM   #14
Google the J-mod, you need two drill bits and new separator plate gaskets Totals to about $60. You drill out specific holes in the separator plate to a bigger diameter and remove a few accumulator springs. The mod was designed by one of the primary Ford 4R developers (Jerry Wroblewski which is why it is called "J-mod") and is one of the best things you can do to your car if you have an auto.
Old 07-20-2014, 01:25 PM   #15
superdrift's Avatar
Ok so can i get a clear answer how much can my transmission handle?
Old 07-20-2014, 02:15 PM   #16
It'll handle plenty of power. I'd be more worried about a stock bottom end 4.6 giving out before the transmission
Old 07-20-2014, 02:52 PM   #17
It's a 4r70w and I already gave that answer. I also mentioned how the v6 trans can't physically bolt to a 4.6l.
Sent from my VS980 4G using Mustang Evolution mobile app
Old 07-20-2014, 03:27 PM   #18
superdrift's Avatar
If i do decide to replace my engine im getting a new transmission. Just wondering if i could temporarily keep it
Old 07-20-2014, 07:53 PM   #19
As long as you have the V6 it will be more than fine. If you are asking if it will be ok for awhile behind a 4.6L temporarily... again it won't bolt up.
Old 07-20-2014, 07:59 PM   #20
superdrift's Avatar
Na i was wondering if it was possible
T-Max Transmission Thermostat Trojan Horse 1979-1995 Mustang GT 3 08-27-2011 03:35 AM
max camber w/ even tire wear? tedness Pre-2005 V6 Mustang 1 07-29-2005 02:16 PM
The Tornado//Spiral Max Seph Pre-2005 V6 Mustang 10 07-08-2004 11:09 AM
3D Studio Max Dan The Bar 4 12-05-2003 06:55 PM
06:23 AM
