Driveshaft vibration? - Mustang Evolution
Old 07-16-2014, 04:51 PM   #1
BamaStang93's Avatar
I got a 99 v6. I've been trying to trouble shoot this problem for sometime now. When transmission is under load in any gear 1st-5th, I'm experiencing a hard vibration under my butt. Not only that but also when I press down on the accel, a single pop will come from what sounds like under the car. I thought it was the u joints so I already replaced both of them. Could it be the driveshaft being imbalanced? Any thoughts or advice would be greatly appreciated.
BamaStang93 is offline   Reply With Quote
Old 07-16-2014, 09:54 PM   #2
samuelsmith's Avatar
Sounds like a trans mount.
Old 08-01-2014, 08:59 AM   #3
I figured out what it was Samuelsmith. The spark plug wire was resting on the exhaust manifold and the heat pretty much ate through the wire. Click image for larger version
Name:	ImageUploadedByMustang Evolution1406905164.918747.jpg
Upgrade Your Weak Stock Driveshaft with The Driveshaft Shop at AmericanMuscle AMWill AmericanMuscle 1 03-16-2014 02:18 PM
Driveshaft vibration with 1 piece alum DS RLF9409 2005-2010 Mustang GT 8 03-14-2011 07:43 AM
Odd Vibration and sound The Bandit Pre-2005 V6 Mustang 10 01-16-2005 06:00 PM
Torque specs for vibration dampener ridelikehell Pre-2005 V6 Mustang 4 02-20-2004 05:45 AM
Vibration Dampener Torque Specs ridelikehell The Bar 2 02-17-2004 05:39 AM
09:51 PM
