oil change - Mustang Evolution
Old 07-19-2014, 10:16 AM   #1
MigV6stang's Avatar
Region: Arkansas
oil change
alright so it's about time I get an oil change for my girl and I'm sorta clueless on what kind of oil I need .... do I have to use sw20? or what is recommended and what kind of filter should I use? thanks ๐Ÿ‘
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
MigV6stang is offline   Reply With Quote
Old 07-19-2014, 11:19 AM   #2
samuelsmith's Avatar
5w-20
Old 07-19-2014, 11:48 AM   #3
Blakhwk's Avatar
5-20 and I usually by the motorcraft filter from any store even Walmart carries it.
Visca Barรงa
Blakhwk is offline   Reply With Quote
Old 07-19-2014, 11:54 AM   #4
MigV6stang's Avatar
Region: Arkansas
thanks man I appreciate it
StreetStangMiggz
Old 07-20-2014, 07:46 PM   #5
BamaStang93's Avatar
I run 5w-30
BamaStang93 is offline   Reply With Quote
Old 07-21-2014, 01:16 AM   #6
MigV6stang's Avatar
Region: Arkansas
Originally Posted by BamaStang93 View Post
I run 5w-30
does ur car run just as good as 5w20?
StreetStangMiggz
Old 07-21-2014, 10:50 AM   #7
Well I have a 99 35th anniv. The emissions label under the hood says "use 5w-30". But yeah it runs fine. If you were to put 5w-30 in your car, I'm sure it would run fine too.
Old 07-21-2014, 02:34 PM   #8
This is toooooo EASY
If the label tells you to use 5W-30 Why would you really want to use any other weight?????????
DUH !!!!!!
Old 07-21-2014, 03:09 PM   #9
MigV6stang's Avatar
Region: Arkansas
never said I was
I was just asking which weight was better
StreetStangMiggz
Old 07-21-2014, 03:19 PM   #10
The best weight is this:::
The one "FORD" recommends is the best."""ALWAYS""
The important thing is to use a good quality motor oil weather you use semi-synthetic or full synthetic you want to use a brand with this symbol on the bottle.
Old 07-22-2014, 01:48 AM   #11
MigV6stang's Avatar
Region: Arkansas
do I gave to use motor craft or can I go with Castrol gtx?
StreetStangMiggz
Old 07-22-2014, 07:55 AM   #12
I'm pretty sure Castrol GTX does have the "API" symbel
If you do use it then change the oil more often, Every 3,000 miles. GTX is not semi or full synthetic.
PS:
I just looked up the GTX and it is Certified and does have the symbol on the bottle.
Your good to do.
Old 07-22-2014, 11:02 AM   #13
MigV6stang's Avatar
Region: Arkansas
PS:
Your good to do.
alright thx a lot man ๐Ÿ‘
StreetStangMiggz
First oil change what oil sinister 2011-2014 Mustang GT 48 08-18-2014 08:57 AM
To change or not to change? Djulin 2011-2014 Mustang GT 13 04-03-2013 11:20 AM
Oil, Oil Additives, Oil Filters, FACTS robb15033 General Mustang Discussion 2 08-02-2012 12:37 PM
Oil change....... cagedthought Pre-2005 V6 Mustang 24 10-04-2003 01:35 PM
Oil Change problems 94sexystang Pre-2005 V6 Mustang 20 09-30-2003 11:14 PM
05:56 AM
