03 04... any difference?? - Mustang Evolution
Old 07-20-2014, 09:37 PM   #1
I was wondering what is the difference between an 03 v6 automatic mustang and an 04?
Sent from my Galaxy Nexus using Mustang Evolution mobile app
Antdroid23 is offline   Reply With Quote
Old 07-20-2014, 11:43 PM   #2
Region: Utah
04 has 3.9 vs 3.8, slightly more power but not that much, pretty much the same
willylin is offline   Reply With Quote
Old 07-22-2014, 03:27 PM   #3
mazen123's Avatar
Theres actually no power difference at all
mazen123 is offline   Reply With Quote
Old 07-22-2014, 04:12 PM   #4
samuelsmith's Avatar
Credit to sonicpony
People often ask what the differences are between the Essex 3.8 liter v6 engine and the Essex 3.9 liter v6 engine. This article is here to explain the differences between the two engines, reason for replacement of the 3.8 liter v6 mid year 2004, and whether modifications for the 3.8 liter engine apply to the 3.9 liter engine.
The Essex 3.8 liter OHV v6 engine was used in the model year 1999 thru mid 2004 year base mustang. It utilized the split port cylinder design originally used on the Ford Windstar. For 1999 and 2000, the 3.8 did not use intake manifold runner control (IMRC). It left all 12 intake runners open at all times, producing 190 horsepower at 5250 rpm and 220 foot pounds of torque at 2750 rpm.
In 2001, Ford decided to add IMRC to the 3.8 liter bringing total output 193 horsepower at 5500 rpm and 225 foot pounds of torque at 2800 rpm.
Starting October 7, 2003, the Essex 3.9 liter was installed in model year 2004 base mustangs. The reason for this switch was due to the model change from the Windstar to the Freestar minivans. The Freestar used the 3.9 v6 just as the Windstar used the 3.8, so it is not odd that it was handed down to the v6 mustang. Ford felt that using the same engine would avoid manufacturing complexities and potential complications of building similar, yet different engines side by side.
The only significant difference between the 3.8 and the 3.9 liter v6 engine is the piston stroke and reduction in the pin to dome length, resulting in an increase in displacement. The piston stroke increased from 86.00mm to 88.00mm, and the pin to dome length reduced from 38.83mm to 35.83mm. These changes resulted in increased displacement from 3.79 liters to 3.88 liters. (as with many engines, the manufacturers rounded the displacement number up) The cylinder bore, compression ratio, horsepower and torque went unchanged for the 3.9 liter v6 engine.
Many have asked questions related to whether 3.8 v6 engine aftermarket parts will work on 3.9 engines. Several engine modifications will work for the 3.9 engine that are only labeled to work on the 3.8 engine. For example, the American Muscle CAI Kit is only listed as working on 1999 to early 2003 v6′s, but it will work just fine on late 2003 3.8′s and all 3.9′s. Most vendors and manufacturers relay whether their parts will work for both engines.
So the bottom line is don’t be afraid of the 3.9 engine. The only difference is internally, which doesn’t affect mods outside of the guts of the engine. They are very compatible with the 3.8 engines, and are just as mod friendly.
There is no difference in power output or efficiency between the two engines..so if you have a stock 99+ 3.8 and your buddy has a stock 3.9, he won’t beat you due to any extra engine power, it’ll simply be a driver’s race!
Old 07-22-2014, 05:27 PM   #5
Cool thanks
Is there any difference in 5.0 engine bocks? Hellish Horse 1979-1995 Mustang GT 7 01-03-2014 07:55 AM
Any difference between 3.7 and 5.0? Red Stallion 11 General Mustang Discussion 2 12-21-2013 08:53 AM
2010 GT w/ Calif. Emissions any difference Ksquared 2011-2014 Mustang GT 3 09-19-2012 05:10 PM
Difference between Michael Jackson and Neil Armstrong *WW* DropTop_Stang The Bar 18 10-28-2003 02:20 PM
Difference between Liberals, Conservatives and Southerners Ken The Bar 6 10-24-2003 05:19 PM
01:37 AM
