Drivetrain recomendations/questions - Mustang Evolution
Old 08-01-2008, 10:29 AM   #1
Scorpion1's Avatar
Well Im looking for good brands for the following as I plan on lightening the car up substantially and redoing the entire drivetrain in prep for the TT or M112 kit I should be getting sometime in the future.
Transmission: What fits? I know I have a T5 now, Im only planning on making 600whp at most on this car, so whats a good transmission?
Obviously Ill be getting an 8.8 rear with 3.73 gears and T-lock/posi. I was told this will bolt right in so Im assuming I can use a GT aluminum drive shaft as well?
Clutch/Flywheel. Whats a good combination? Brand? I know I dont need it but I want it to rev quickly and I know this will help so whats a good lightweight flywheel?
finally, the suspension. Im going with eibach springs (since they come with the tubular K) all around with Tokico shocks/struts. Is this a good combination? What multi-link sway bars should I go with? Finally the most important part. Ill be getting 17x8 in front and 18x10.5's for the rear summer wheels, whats a good tire and size for these?
WiCK3D_SiX
Scorpion1 is offline   Reply With Quote
Old 08-01-2008, 03:14 PM   #2
Send a message via AIM to duncan mcdougal
Re: Drivetrain recomendations/questions
Are you paying someone to do all this work? It seems like you have a lot of research to do before the project starts.
I would start with just getting to know your car and the differences between the models in your generation.
Also look at promotion or g-force t-5 transmissions for 600 hp handling.
duncan mcdougal is offline   Reply With Quote
Old 08-01-2008, 03:19 PM   #3
1234's Avatar
flywheel id say spec and spec satge 3 clutch for the clutch. Id say 245v55 in the front 315 35 in the back and yes thats a good combination for suspension
Old 08-01-2008, 06:23 PM   #4
I would go with a stage 2+ because of the better daily driver characteristics.
Remember with the spec flywheel you can use the GT's 10.5" clutch or the V6's 11".
Old 08-01-2008, 07:23 PM   #5
1234's Avatar
did you read any of the orignal post he said 600hp i would say stage 3 would be alot better in that situation. The drivability issue with spec clutches is not bad at all. Stage 2 feels lighter than a stock clutch.
Old 08-01-2008, 11:06 PM   #6
Scorpion1's Avatar
yeah Im still learning at a decent pace. Usually takes me about 2 months to find a cars limits but these tires suck haha. well im off to work again...
WiCK3D_SiX
Old 08-02-2008, 07:40 PM   #7
A stage 2+ clutch has better drivability and handles 635 lb-ft vs the 685 of the stage 3. I would spend the extra cash for the 2+ because you never know when you are going to get stuck in rush hour traffic.
Old 08-04-2008, 10:52 AM   #8
1234's Avatar
yeah but you dont want to push the limits of a clutch to find out you should of went with stage 3
Old 08-04-2008, 11:18 AM   #9
Scorpion1's Avatar
I found out my buddies GT has the stage 3 kit, after a roll through town (and considering 99% of my driving is highway) I will be going with the stage 3 clutch. Its alot softer at the pedal than I expected. Thanks for all the help guys.
WiCK3D_SiX
Steam Vac Recomendations? 99ford Mustang Audio & Video 3 02-21-2010 08:40 AM
Tire recomendations? 232stang01 Mustang Wheels & Tires 8 12-29-2004 07:14 PM
Oil recomendations/ Check engine light Neptuno Pre-2005 V6 Mustang 6 09-03-2004 08:09 AM
questions about drivetrain Johnny D Pre-2005 V6 Mustang 12 03-16-2004 09:12 PM
Drivetrain Stickies Brent Pre-2005 V6 Mustang 0 08-10-2003 05:31 PM
09:56 PM
