Taylor Helix throttle body spacer - Mustang Evolution
Old 07-27-2014, 08:04 PM   #1
02PonyPack's Avatar
Anyone try this on their six? Put it on today and I find it awesome. Adds whistle to the throttle body and tone to the exhaust. Acceleration comes easier too.
Sent from my SGH-I747M using Mustang Evolution mobile app
02PonyPack is offline   Reply With Quote
Old 07-28-2014, 12:03 PM   #2
samuelsmith's Avatar
I use to think these were bs. I bought one and keep it for months without installing it. But after installed I was a changed man.
Old 07-28-2014, 07:50 PM   #3
xfree143's Avatar
Where did you purchase it?
xfree143 is offline   Reply With Quote
Old 07-28-2014, 08:03 PM   #4
02PonyPack's Avatar
Ebay
Old 07-28-2014, 08:11 PM   #5
02PonyPack's Avatar
http://www.jegs.com/webapp/wcs/store...&storeId=10001
Old 07-28-2014, 08:15 PM   #6
JoeyM91's Avatar
Gonna have to call shenanigans. There's mountains of evidence that they don't do what they say they do. What DOES happen is you get a small amount of low end power from the swirling effect, BUT this creates turbulence in the intake's plenum and chokes it off on the upper end of the power band. You lose more overall than you gain.
These were meant for pickups that needed a bit more low-end grunt for towing.
Old 07-28-2014, 08:21 PM   #7
02PonyPack's Avatar
There's been plenty of discussions on that topic. Some say its great, others say its crap. The engine is an air pump, doesnt it make sense to want more air in?
Old 07-28-2014, 08:24 PM   #8
JoeyM91's Avatar
It doesn't increase your airflow. It's drilled to "swirl" the air that's already coming in to try to increase the pressure, which it does....at first. But like I said, this creates turbulent air in the intake plenum which chokes the engine on the high end.
Old 07-28-2014, 08:28 PM   #9
JoeyM91's Avatar
Here's an explanation that might help:
Do Throttle Body Spacers Really Work on Fuel-Injected Vehicles? | eHow
Old 07-28-2014, 08:34 PM   #10
02PonyPack's Avatar
http://www.carsdirect.com/aftermarke...e-body-spacers
Old 07-28-2014, 08:36 PM   #11
02PonyPack's Avatar
It may not be right for all engines but it works on mine and im happy.
Old 07-28-2014, 08:43 PM   #12
JoeyM91's Avatar
Eh, if you like it go for it, I'm just saying you're sacrificing high end power for a small low end.
Also from your own article, since the 3.8L has Multi-Port Injection:
Type of Engine
These spacers mainly benefit older engines. In particular, those with fuel injection systems that have the fuel go directly into the throttle body, where it then mixes with air before going into the combustion chamber. It also can help with carburetor systems. However, if the vehicle has a multi-port fuel injection system or other top of the line system, then that small change in the air vortex will not make any difference to the performance, torque or horsepower. Therefore, before you go out and purchase a spacer, make sure your engine can actually benefit from having this upgrade.
Old 07-28-2014, 08:55 PM   #13
02PonyPack's Avatar
Did you ever try one or your stuck on the skeptic side?
Old 07-28-2014, 09:00 PM   #14
JoeyM91's Avatar
I did at one time, and all it added was a slight whistling noise. That being said, the 3.7 and the 3.8 are very different engines.
Old 07-28-2014, 09:02 PM   #15
02PonyPack's Avatar
Cause the more I search, more it makes sense. Some companies even tested it out on dynos with gains...
Old 07-28-2014, 10:00 PM   #16
The spacer add 200 rpms on my factory tune and my street tune now gets a cell saying that my car is running lean. With the mods I have sooner or later a new weakness always occurs. The box on the spacer says it responds at 3500 rpms+.
Old 07-29-2014, 07:19 AM   #17
02PonyPack's Avatar
So an adjustment needs to be done on a tune?
Old 07-29-2014, 02:47 PM   #18
You do not have to buy a tuner because you bought a throttle body spacer. But I would recommend buying a tuner. It is one of the better mods. Some mods are not worth buying for minor gains.
Old 07-29-2014, 03:01 PM   #19
02PonyPack's Avatar
I have a tuner, tuned to 91 octane
Old 07-29-2014, 03:07 PM   #20
02PonyPack's Avatar
Was wondering if an adjustment needs to be done. U said u burn richer with the spacer...
Old 07-29-2014, 04:27 PM   #21
I am getting a lean code..........meaning the car is running lean. More air and not enough fuel makes the car run lean. Eventually I will pay $100 for a new tune. Bama does not tune for the 4.2 intake.
Old 07-29-2014, 04:32 PM   #22
02PonyPack's Avatar
Ive got a diablo. I can change the fuel/air mixture to what I please. Im not getting a code tho, so I guess im fine...
Old 08-01-2014, 11:27 PM   #23
davidcseifert's Avatar
Region: Arkansas
Name:   ImageUploadedByMustang Evolution1406957267.099511.jpg
blower/new cam soon
Freakin Taylor Wires 08Mustang 2005-2010 V6 Mustang 2 06-03-2013 09:04 PM
Throttle Body Spacer ridenmystang Mustang Parts for Sale and Wanted 2 12-16-2006 05:00 PM
Throttle Body Spacer. strike1980 Pre-2005 V6 Mustang 4 06-09-2005 11:39 AM
rpm motorvator throttle body spacer sctalbott Pre-2005 V6 Mustang 2 02-03-2004 11:27 AM
» Members Mustangs
Boss GT
dimo
Trouble
naw351
Add your Mustang
04:59 PM
