radiator Question - Mustang Evolution
Old 07-28-2014, 06:03 PM   #1
ProjectTurboV6's Avatar
radiator Question
Will an 96GT radiator work with my 98 3.8? Bought the wrong radiator and hoses so chime in if you have any advice! I'm putting in a 96 4.6 4v in a couple months. Just need this to work for now
ProjectTurboV6 is offline   Reply With Quote
Old 07-28-2014, 06:18 PM   #2
Bravebowhunter's Avatar
Flex hoses would peobably be best for that
1967 coupe 351w 5 speed dual exhaust long tube headers, 2000 v6 5 speed dual exhaust lowering springs drilled and slotted rotors, 2005 ford ranger single cab 3.0 under drive pulleys auto 8.8 rear end with 4.10 gears
Bravebowhunter is offline   Reply With Quote
Old 07-28-2014, 06:29 PM   #3
I haven't looked yet, but are you thinking the GT hoses won't work with the 3.8 motor? They're silicone mishimoto hoses...
Old 07-28-2014, 07:01 PM   #4
Idk if there different you can go to the parts store and compare the part numbers between the two engine. I just listed the flex hoses because they will deffinately work no matter what. Measure the outlet on the engine and measure the outlets on the radiator so you can find a hose with the right diameter ends
radiator question fordracing30 Pre-2005 V6 Mustang 0 02-19-2014 10:11 PM
Radiator overflow question? 94gtconvert 1979-1995 Mustang GT 4 09-19-2013 07:24 PM
Radiator Question 93mstnglx 2.3 Mustang 4 11-02-2012 09:10 AM
Radiator question? WhiteCobra94 1979-1995 Mustang GT 5 08-22-2011 11:14 AM
Radiator problems robert0803 Pre-2005 V6 Mustang 14 08-12-2003 11:26 AM
03:05 PM
