Loss power....any money don't understand!!!!!!!! - Mustang Evolution
Old 07-28-2014, 09:50 PM   #1
joshuav6's Avatar
I've got a 06 v6 automatic. Lost power didn't want too shift acting like it's was low on power got it towed home...but a new fuel pump in getting 50 psi like it should still won't turn over...changed out the plugs and wires turns over but pops than dies like it not getting air or power too the motor....would you have any idea what it could be? Maybe regulator or a Cadillac converter or could have jumped time? Or bad fuel injection?
Sent from my LG-D801 using Mustang Evolution mobile app
joshuav6 is offline   Reply With Quote
Old 07-29-2014, 05:20 PM   #2
maybe ignition coil. any codes?
"Joey" 2004 v6: SR CAI, MPT Tuned, 4.10 gears
Miri is offline   Reply With Quote
Old 07-29-2014, 06:30 PM   #3
joshuav6's Avatar
Codes for bad wires or plugs...change out wires and plugs...but still don't want too turn over
Old 07-29-2014, 06:33 PM   #4
Eturner's Avatar
Starter maybe?..
Old 07-29-2014, 10:48 PM   #5
joshuav6's Avatar
Ok thought that too but the engine turns over than acts like it's choking or no power to keep it running. I did a compression check on the engine all cylinders have 150 psi, got spark and fuel, when I spin it over fuel pressure starts at 60 psi but drops below 30 psi right as it starts? No codes though I got charger on the battery Killed it cranking , an open diode in the alt could also cause a spike keeping the car from running ...maybe? got spark, compression and fuel I am missing something?
Old 07-30-2014, 08:19 AM   #6
Eturner's Avatar
Sounds like something that happened to me a year ago!.. Might be your fuel pump!.. Fuel pressure shouldn't drop when your starting it!..
Old 07-30-2014, 08:45 AM   #7
joshuav6's Avatar
I just bought a new one and dropped it in Monday
Old 07-30-2014, 10:41 AM   #8
Eturner's Avatar
Only other thing I can think of is a clogged fuel filter!.. Unless you changed that also!..
Old 07-30-2014, 12:44 PM   #9
joshuav6's Avatar
New fuel pressure regulator new fuel pump new spark plugs and wires check the coil pack running like it should check the fuel filter blew through it like normal I'm stumped
Old 07-30-2014, 04:08 PM   #10
PRoss.20's Avatar
Region: Arkansas
Weird. That's literally like everything haha. Egr valve maybe??? I have no clue.
PRoss.20 is offline   Reply With Quote
Old 07-30-2014, 04:51 PM   #11
Eturner's Avatar
I would replace to fuel filter with a new one!.. If that don't work, then the only other thing I can think of is a slight fuel leak some where!..
Are you smelling any Raw Fuel anywhere?..
Old 07-30-2014, 04:56 PM   #12
PRoss.20's Avatar
Region: Arkansas
Possible you have something wrong with your fuel line like he said maybe a leak or bend from hitting something that is keeping it from pushing enough fuel to the engine after it starts.
Old 07-30-2014, 07:17 PM   #13
joshuav6's Avatar
Yeah go ahead and change the filter out but when I put a gauge to check the fuel pressure I'm getting 60 psi but when I turn the motor over it drops down to 30 psi I change new fuel pump I got a new fuel pressure regulator new Sparks and wires I check the coil pack one bank is 1.3 oms from being normal but still would have enough juice to fire up I checked all my relays I check my modules in the trunk I checked I button under the driver kick panel..
Old 07-30-2014, 07:24 PM   #14
joshuav6's Avatar
Maybe a time jump? Idk 450bucks in the hole and the Damn thing still don't want too fire up...like it's in a stall mode or something...
Old 07-30-2014, 08:24 PM   #15
Hi there me and my son just towed his mustang v6 home.We pulled the converts and gutted them and i finally runs and drives but now we have an issue with shifting points are off ,and the engine light is on.hopefully this helps but the engine lite is another issue.
diehls7758 is offline   Reply With Quote
Old 07-30-2014, 10:15 PM   #16
joshuav6's Avatar
Thanks I'll look in to that
Old 07-31-2014, 12:13 AM   #17
Region: Iowa
I'm not sure if I am correct but there is the mass air flow for the air and fuel mixture and then there is the map sensor which controls spark and fuel
Midwest5.0 is offline   Reply With Quote
Old 07-31-2014, 12:17 AM   #18
Region: Iowa
Map sensor
Old 07-31-2014, 01:49 AM   #19
joshuav6's Avatar
Where's the map sensor located at? That's sounds like something needing to be looked at
Old 07-31-2014, 02:00 AM   #20
joshuav6's Avatar
I took off the maf sensor and cleaned it real good....but the map sensor is something I haven't looked at
Old 07-31-2014, 06:20 AM   #21
Region: Iowa
The manifold absolute pressure (MAP) sensor is a common component on modern fuel injection engines that vaporize gasoline by pumping fuel into the engine under high pressure. The MAP sensor helps the engine determine its optimal combustion needs by calculating the mass of the air going into the engine, air temperature, and the rotations per minute of the engine. This allows the engine’s electronic control unit (ECU) to determine the density of the air flowing into the fuel mixture and the ECU can then adjust the both the air flow or fuel flow to maximize performance.
Old 07-31-2014, 07:08 AM   #22
joshuav6's Avatar
Where is it located at?
Old 07-31-2014, 07:17 AM   #23
Region: Iowa
What year is ur car ,after a certain year the map sensor became the mass air flow sensor
Old 07-31-2014, 07:19 AM   #24
Region: Iowa
Iac
Throttle positions sensor
Mass air flow
PVC valve
Crank sensor
O2 sensors
What's the year and engine
Old 07-31-2014, 07:34 AM   #25
joshuav6's Avatar
2006 4.0 v6
Old 07-31-2014, 09:37 AM   #26
Region: Iowa
Let me think about it
Old 08-02-2014, 08:42 PM   #27
joshuav6's Avatar
Quick update...... New fuel pump new fuel driver control module new spark plugs and wires new fuel pressure regulator dump the Cadillac converters so there's no bad compression starts runs at an idle but when I give it gas it dies pulled the injectors don't look bad still clean them put it back in same thing I'm stumped any suggestions?
Old 08-02-2014, 08:43 PM   #28
joshuav6's Avatar
Power going to injectors pumps pushing out 50 pounds per pressure
Old 08-02-2014, 10:45 PM   #29
Region: Iowa
O2 sensors can cause a car not run right or shift right it won't let the correct amount of fuel to the motor just did them on my car
Old 08-02-2014, 11:03 PM   #30
joshuav6's Avatar
Humm 02 huh? I didn't even think about that
Old 08-02-2014, 11:06 PM   #31
Region: Iowa
Yea it reads the exhaust fumes ,so if it is reading wrong it will cut out the engine
Old 08-02-2014, 11:08 PM   #32
Region: Iowa
Yea
Old 08-05-2014, 09:00 AM   #33
joshuav6's Avatar
Quick update!!!!!Cadillac converters then whatever was in the Cadillac converter is clogged up my muffler
Old 08-05-2014, 09:08 AM   #34
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Ok. I've gotta correct you on this since you've done it multiple times. It's spelled catalytic, not Cadillac lol.
Sent from the Death Star.
2012 Kona Blue 3.7L V6:
Old 08-05-2014, 09:09 AM   #35
I Just posted something similar in his other thread
Loss power....lost money still don't understand...!! joshuav6 2005-2010 V6 Mustang 5 08-05-2014 09:19 AM
Power Steering Hose??? I do Not understand!! RodgersMustang 1996-2004 Mustang GT 12 06-21-2014 06:33 PM
I don't think you understand this game.... Brent Pictures and Videos 5 03-12-2010 11:31 AM
Why? I just don't understand... sonicpony03 Pictures and Videos 7 01-12-2010 11:33 PM
*ww* possible - it's official, I completely don't understand my gf jimmy_beaner The Bar 26 09-20-2005 12:07 PM
03:32 AM
