Rear end ? - Mustang Evolution
Old 07-31-2014, 01:23 PM   #1
Bravebowhunter's Avatar
Rear end ?
I have a 2000 v6. What size is the rear end from side to side? What year 8.8's will fit? I may have found a rear end out of a 94 gt with 3.27's will that work?
1967 coupe 351w 5 speed dual exhaust long tube headers, 2000 v6 5 speed dual exhaust lowering springs drilled and slotted rotors, 2005 ford ranger single cab 3.0 under drive pulleys auto 8.8 rear end with 4.10 gears
Bravebowhunter is offline   Reply With Quote
Old 07-31-2014, 07:04 PM   #2
ProjectTurboV6's Avatar
Pretty sure only 99-04 rears will fit your 2000 because the 99-04 are longer than the other older rears
ProjectTurboV6 is offline   Reply With Quote
Old 08-01-2014, 12:39 AM   #3
A 94 rear end will fit but since the 99-04 are longer you will need spacers or else the wheels will sit way inside the fender.
Old 08-01-2014, 12:51 AM   #4
Probably need 1in spacers, right?
Old 08-01-2014, 04:38 PM   #5
mazen123's Avatar
99-04 mustang read ends are 3/4 of an inch longer on each side compared to a 94-98 rear end. A total of 1.5 inches shorter
mazen123 is offline   Reply With Quote
Old 08-01-2014, 07:31 PM   #6
Ok cool so if I got a 94-98 8.8 and put 1.25 inch spacers on it would give me a little bit of a stance/wider look.
Old 08-01-2014, 09:48 PM   #7
Yes that is correct. The spacers along with the 94-98 8.8 will look perfect. I completed a 04 rear end swap to a 97. It is indeed 3/4th of an inch wider on both sides.
Everything bolts up exactly the same. You might need an impact though. And I would definitely recommend a lift, if not. It'll be a long day. The swap took me 3 hours.
Sent from my SM-N900V using Mustang Evolution mobile app
sunderwood is offline   Reply With Quote
86 front end into an 89 front end Beatjunkiexorge 2.3 Mustang 1 05-18-2013 07:07 PM
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 03:43 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
Rear End Swap Ken Pre-2005 V6 Mustang 13 10-02-2003 01:49 PM
finished my rear end swap Monkey Pre-2005 V6 Mustang 3 07-27-2003 05:23 PM
01:28 PM
