Cylinder head temp sensor location. - Mustang Evolution
Old 08-03-2014, 06:52 PM   #1
Adriangozal's Avatar
I have a 2001 v6 and as the title says, I am trying to locate it so I can replace it. I have searched every where. A good description if where it is exactly would be very useful or even a picture of it. Thanks
Adriangozal is offline   Reply With Quote
Old 08-05-2014, 10:25 AM   #2
davidcseifert's Avatar
Region: Arkansas
Back of drivers side head right by the freeze plug, it's the only thing on the back of the head and is a PITA to replace while the head is still ok the car. Undo the wire harness from the holder to get a little more room just be sure you put it back so it doesn't lay against the head.
blower/new cam soon
Old 08-10-2014, 01:33 PM   #3
Thank you for the info
Water temp - Thermostat & Head Temp ArtU 2011-2014 V6 Mustang 3 07-19-2013 08:30 PM
Cylinder head temp? McQueen Boss Mustang 5 10-28-2012 08:27 PM
IAT Sensor Location??? XxViSiOnxX Pre-2005 V6 Mustang 11 10-27-2006 06:53 PM
Cam sensor numbers and location... DarkShadow 1996-2004 Mustang GT 3 07-09-2006 08:16 PM
Location Location Location Ken The Bar 9 08-07-2003 08:51 AM
01:46 PM
