Door hinge - Mustang Evolution
Old 08-07-2014, 05:05 PM   #1
Alexanderv6's Avatar
Region: Oregon
Door hinge
Ok, so i finally got a door for the stang for 175.00 all together got a great deal from Hillsboro Auto Wrecking. If any one lives out in oregon/portland/beaverton . Here is my issue, i put it back together to see if it alined good, everything was perfect except for i gotta pick it up a bit and then close it. Could it be the Hinge on the bottom that is busted? And the reason why i got a new door was because i busted the old one, so i am just verifying if that could be the cause to my issue, just need some extra advice before i buy the new hinge for it. Thank you guys
Name:	ImageUploadedByMustang Evolution1407452341.535348.jpg
ID:	163086Click image for larger version
Name:	ImageUploadedByMustang Evolution1407452376.837276.jpg
Alexanderv6 is offline   Reply With Quote
Old 08-08-2014, 12:56 PM   #2
Jaytraeg's Avatar
I have the same problem, brother. I'm actually going outside right now to see what I can see. I'll let you know of any findings.
Sent from my iPod touch using Mustang Evolution
Jaytraeg is offline   Reply With Quote
Old 08-08-2014, 03:05 PM   #3
misterpancho95's Avatar
Yes I had that same problem turns out they were rusted and bent a little if you replace them they should pick up your door.
Sent from my 831C using Mustang Evolution mobile app
misterpancho95 is offline   Reply With Quote
Old 08-08-2014, 03:31 PM   #4
Region: Oregon
Thank mans. Ill just order them
Old 08-08-2014, 03:41 PM   #5
Jaytraeg's Avatar
Yeah, my top hinge is pretty bent, but I'm sure the bottom one will do the same. Tell me where you find them the cheapest, I kinda want to get one too.
Old 08-08-2014, 03:48 PM   #6
Region: Oregon
Old 08-08-2014, 04:10 PM   #7
Region: Oregon
Aight ill keep u posted.
Old 08-08-2014, 05:07 PM   #8
You can get them cheap at Autozone for like $24 bucks
Old 08-08-2014, 05:15 PM   #9
The only other thing you would need is a hung puller and placer that you can get as well
Old 08-08-2014, 05:16 PM   #10
Region: Oregon
Is that a removal kit?
Old 08-08-2014, 06:47 PM   #11
Yeah
Sent from my HTC0P3P7 using Mustang Evolution mobile app
Old 08-08-2014, 06:48 PM   #12
Region: Oregon
Yeah
Ok ill look into it, thanks.
Old 08-08-2014, 07:42 PM   #13
No problem
Hood hinge bolts fordfan100 2011-2014 V6 Mustang 5 11-27-2017 12:08 PM
Hinge Pins Fballman9 1979-1995 Mustang GT 4 09-23-2013 11:42 AM
Any one know where i can find a door/door-skin for a 94 gt convertible? main seal to? 94gtconvert 1979-1995 Mustang GT 1 03-25-2013 12:35 AM
Replacing stock fuel door with stock fuel door...help? MarshallYoung 2005-2010 V6 Mustang 13 07-23-2012 11:23 PM
Looking for a ford mustang driver side door? I live in Ca. and need a silver door.? lugaidh General Mustang Discussion 2 03-09-2010 11:11 AM
12:44 AM
