nitpicking on my cold air setup - Mustang Evolution
Old 12-08-2003, 09:00 PM   #1
tire's Avatar
Send a message via AIM to tire
yeah, i know it's not horribly important but i wanted to see what the more experienced guys here had to say about this... i will probably keep it like this but wanted imput. you all know how normal CAI goes, but here is my humungo-filter and ghetto home depot setup + mac cai...
-austin
tire is offline   Reply With Quote
Old 12-08-2003, 09:26 PM   #2
I dont see it helping out alot. I mean it might be a few degrees cooler but it has more bends.
Not experience tho so thats just a guess
Old 12-08-2003, 10:26 PM   #3
That's how the older mac cold airs were. They ended up interfering with smog
pumps (99-00), cost more (more material and bends), harder to install and yes
they have more bends so that's more of a restriction. These are all the logical
(not necessarily why mac did it) reasons I can think of for them going to what
they have now.
-Mik
Redlined Performance Mustangs
Cylinder Head / Intake Porting, Camshafts, Pistons, Cold Airs/Pulleys
www.rpm-mustangs.com
http://rpm-mustangs.com/pictures/KEcrank.jpg
mikael is offline   Reply With Quote
Old 12-08-2003, 10:38 PM   #4
Monkey's Avatar
wow, we have an artist on our hands. way to use MS Paint Michalangelo.
anyway, that is exactly what my mac looks like. except the MAF to TB tube is a little more round, but thats cause my TB is at a 90* angle where 99+s are at like a 50*
Old 12-08-2003, 11:39 PM   #5
tire's Avatar
i believe it to be a restriction because mine turns down 90 deg to point straight down, after the piping clears the fenderwell, that is. the filter is huge and is getting hit by air a lot from the fog light hole but it probably doesn't make a difference.
any suggestions? i can't do much cause the filter is huge and it won't fit any way else, period, i tried.
any possible (1rwhp+) benefits to making a little funnel out of the fog light hole and hitting it harder with more air? i'm anal, that's just how i am. i feel like a guy asking about an air silencer and the gains from removing it.
and brandon... it DOES look decent for a 5 min job, so i'll just assume you were being sincere with your compliment.
Old 12-09-2003, 12:08 AM   #6
Fishers Stang's Avatar
hey v6power, can you keep me up to date on your progress on this? me and RGR are makin our own Ram-air/CAI for my car, so far I have the "ram-air" part in the fender, and useing the stock air box and the hose from the TB and the fender. we are lookin at adding a 45* and the CAI but cant find the best way with mine being a 98 and a flanged MAF. thanks man, hope yours works well. BTW snow/rain has not gottin into my pipes YET.. i am going to take it off and mod somethings soon. just need time.
Charles
Old 12-09-2003, 12:16 AM   #7
tire's Avatar
ok.
maybe poke holes in the back side of the piping to let water escape. i think the only way mine will work well in rain is to add a piece of plastic or something that angles the air down and then the water will stay down while the air circles back up and around the other side. it doesn't rain a ton here but the more i think of it the more i realize how my current setup is probably not very solid. thanks for pointing out the obvious.
Old 12-09-2003, 12:21 AM   #8
tire's Avatar
pumps (99-00)
when i got my headers i cut off the smog pump hole because it isn't needed. just the 02 sensors. are you saying mine has it? it's a '00.
Old 12-09-2003, 12:31 AM   #9
hey man, I was also thinkin about puttin a screen on it, (i cant spell ither) but i got the idea when my dog jumped into my window that was open, we got soem new stuff to replace the old and now i am lookin at this thinkin that air goes in, but the holes are not to big for snow/water, and yes i found a leaf on my filter.. here is whats i got
Charles
Old 12-09-2003, 12:33 AM   #10
tire's Avatar
that is wise to put on the front of your ram air part but it won't do a thing for snow or water. if anything snow would build up on it and freeze. maybe a more porous screen would still keep most debris out.
Old 12-09-2003, 12:43 AM   #11
mmm i am also thinkin about takin that 45* off the bottom till spring.
Charles
Old 12-09-2003, 08:52 AM   #12
pumps (99-00)
I should have said green state 99-00s.
-Mik
Old 12-09-2003, 04:42 PM   #13
when the filter is that far down it sucks up water.... i would move it up so that its right insdie the fender hole. that is another reason why mac makes them shorter now.
Old 12-09-2003, 04:51 PM   #14
tire's Avatar
go figure guys, it rained this morning. the filter didn't get wet but it wasn't raining hard. i figure if it did, it would get wet. i think a small little panel to avert the rain towards the center of the car would keep it from hitting the filter but still let air in.
Old 12-09-2003, 08:28 PM   #15
BlueDonkey's Avatar
if you really want to know, why wait for rain? Take a hose and get after the area around the CAI.
BlueDonkey is offline   Reply With Quote
Old 12-09-2003, 09:21 PM   #16
Charles
Old 12-13-2003, 07:54 AM   #17
RGR
Send a message via AIM to RGR
LOL!!! I love it!
Actually, I like it a bit better than the tube being shorter
and getting the filter up there where there is less of a
straight shot. WIth that exactly as it is, I would construct
some baffles that sealed off the bottom of the space where
your filter is, to try and trap some extra air and get more
into the filter. It could also have a small area exposed under
the foglight opening to grab more air than the foglight hole alone.
I'd try and draw a pic but Monkey would slay me :yes: :yes: :yes:
I feel like Corey with all these faces :wave: Hi DD!
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 12-13-2003, 08:00 AM   #18
RGR
Yes, Mr. Anderson...[/matrix]
Or I could call you charley-charley-chuck-chuck!
That looks like a decent idea, if
we get that 45* piece in there
then it wil line up better with the foglite...
I would look at the screen mounted to the
foglite hole maybe.
Cold Air Intake Scobra Pre-2005 V6 Mustang 16 04-13-2010 04:56 PM
Looking for a cold air intake maxwelmurder Pre-2005 V6 Mustang 10 08-31-2008 08:41 AM
F/S COLD AIR KIT Mrs.sonic GT Mustang Parts for Sale and Wanted 2 04-15-2007 01:29 PM
Mass Air Flow and Cold Air Intake Mike's-stang Pre-2005 V6 Mustang 1 08-20-2004 09:24 AM
02:51 AM
