Welding gears - Mustang Evolution
Old 08-09-2014, 11:44 PM   #1
joe_117's Avatar
Welding gears
Okay so my friend suggested me I should weld my gears so both my rear tires will go instead of one.
Please help me out on this guys! Is it smart or anything because I don't know much about that!
joe_117 is offline   Reply With Quote
Old 08-09-2014, 11:45 PM   #2
joe_117's Avatar
An I hate only doing one wheel burn outs. Help me out guys Click image for larger version
Name:	ImageUploadedByMustang Evolution1407649511.486750.jpg
Old 08-09-2014, 11:50 PM   #3
Tyoung68's Avatar
Dont its not worth it you wont be able to go around corners or in parking lots with out your tires squealing. Looking into a lunch box locker. A lot of off-roaders use them. You dont need to have to gears redone or anything. You can even install it in the car. Thats assuming you have a 8.8? Not to sure about more moderne just classics
Old 08-09-2014, 11:50 PM   #4
joe_117's Avatar
An I hate only doing one wheel burn outs. Help me out guys Attachment 163182
Old 08-09-2014, 11:52 PM   #5
joe_117's Avatar
Any suggestions what I should do? Send me a link to it if you can!
Old 08-09-2014, 11:53 PM   #6
Tyoung68's Avatar
Heres one for an 8.8 just google lunch box locker http://www.aussielocker.com/index.ph...-xd-48831.html
Old 08-09-2014, 11:54 PM   #7
joe_117's Avatar
What do you mean 8.8 lol sorry
Old 08-09-2014, 11:57 PM   #8
Tyoung68's Avatar
And ford 8.8 rear end its the size of the rear end
Old 08-09-2014, 11:57 PM   #9
GunMetalGT's Avatar
Region: New Mexico
It's the type of rear end you have. Ford 8.8 yeah just get a locker don't weld you'll ruin your cars drivability.
GunMetalGT is offline   Reply With Quote
Old 08-10-2014, 12:00 AM   #10
joe_117's Avatar
Oh okay! Lol I actually didn't know the size of it. But you recommend this? Is there any advantages/disadvantages to it? Besides the fact it burns your tires faster.
Old 08-10-2014, 12:06 AM   #11
Tyoung68's Avatar
Well tbh i have no first hand experience with them but iv rear a lot about them iv never seen any power rating on them but im sire they got to be really strong they act like a lsd. Its also able to install it with out having to take the gears out meaning it'll be cheaper to instal it
Old 08-10-2014, 12:08 AM   #12
joe_117's Avatar
Thanks!
Old 08-10-2014, 01:05 AM   #13
joe_117's Avatar
Okay so this is the only thing I need? An this will be the right part correct?
Old 08-10-2014, 01:16 AM   #14
All you really need is limited slip differential. You can get them for your 7.5" diff.
Old 08-10-2014, 01:18 AM   #15
joe_117's Avatar
I thought it was a 8.8?
---------- Post added at 07:18 AM ---------- Previous post was at 07:17 AM ----------
Nevermind, do you have a link?
Old 08-10-2014, 01:24 AM   #16
Tyoung68's Avatar
They make the those lunch box locker for the 7.5. Youd need oil and gasket for your diff cover
Old 08-10-2014, 01:25 AM   #17
joe_117's Avatar
So which one do I need for it?
Old 08-10-2014, 01:25 AM   #18
Tyoung68's Avatar
What do you mean?
Old 08-10-2014, 01:27 AM   #19
joe_117's Avatar
I don't understand when you say 7.5? Is that the rear end I have or is it the 8.8? An which lunch box do I need for the gears
Old 08-10-2014, 01:30 AM   #20
joe_117's Avatar
I Just need to know everything I need so I can get it all done at once.
Old 08-10-2014, 01:34 AM   #21
Tyoung68's Avatar
Well i dont know its your car, but the 7.5 or 8.8 is reference to the ring gear, you should have an ID tag on the rear end. So once you figure that out the google lunch box locker 7.5 or 8.8 which ever one you have and then go what ever one you like and you need some new gear oil and a new diff cover gasket and then youll be all set
Old 08-10-2014, 01:35 AM   #22
joe_117's Avatar
Thanks man!
Old 08-10-2014, 01:38 AM   #23
Tyoung68's Avatar
No problem i found this so just need to look at your diff cover Click image for larger version
Name:	ImageUploadedByMustang Evolution1407656321.576261.jpg
Old 08-10-2014, 01:47 AM   #24
joe_117's Avatar
Name:	ImageUploadedByMustang Evolution1407656800.330704.jpg
It is an 8.8! Thanks! But you said I need a new one if I get this lunch box?
Old 08-10-2014, 01:54 AM   #25
Tyoung68's Avatar
Attachment 163184
No, just the lunchbox it replaces some parts in the diff all you need in parts is the lunch box gear oil and new gasket
Old 08-10-2014, 04:14 AM   #26
If it's a completely stock rear end then it's a 7.5" for the V6. The GT came with 8.8".
Old 08-10-2014, 01:31 PM   #27
mazen123's Avatar
Just get a used ford 7.5 28 spline lsd/posi. I found one on ebay for 81 dollars! I had it installed with 4.10s and a bearing kit and my cars completely changed now
mazen123 is offline   Reply With Quote
Old 08-11-2014, 03:07 PM   #28
joe_117's Avatar
Do you guys know if this would be okay? Click image for larger version
Name:	ImageUploadedByMustang Evolution1407791201.392670.jpg
Old 08-11-2014, 03:11 PM   #29
joe_117's Avatar
Or this..Click image for larger version
Name:	ImageUploadedByMustang Evolution1407791489.266068.jpg
Old 08-11-2014, 04:08 PM   #30
Tyoung68's Avatar
Well those are for GMs sooooo i dont think so
Old 08-11-2014, 04:25 PM   #31
Tyoung68's Avatar
Old 08-12-2014, 01:25 PM   #32
joe_117's Avatar
Name:	ImageUploadedByMustang Evolution1407871507.843742.jpg
I'm dumb-.-
Old 08-13-2014, 08:03 AM   #33
mazen123's Avatar
Attachment 163315
I'm dumb-.-
Thats a good deal! Gears and a posi, all u need a is a bearing kit to install them and rebuild your rear end
Old 08-20-2014, 01:42 PM   #34
Mstngnolan's Avatar
just get a limited slip differential its not worth ruining your car welding it together and messing it up and not being able to get home a lsd only cost 150-300
Mstngnolan is offline   Reply With Quote
Welding the diff willrad00 Pre-2005 V6 Mustang 5 04-16-2012 07:48 AM
Quarter panel welding?? 1faststang Classic Mustangs 6 08-29-2011 06:09 PM
Dual Welding AA-12 Shotgun Brent Pictures and Videos 4 05-17-2011 10:07 PM
Welding axle tubes? systemdz 1996-2004 Mustang GT 3 01-17-2011 11:03 AM
Welding is Winning the War at Iraq bluemustang The Bar 1 03-28-2007 11:53 AM
01:38 AM
