windstar swap and EGR/SMOG? - Mustang Evolution
Old 08-25-2014, 11:12 PM   #1
lemons95's Avatar
I know of a shop in cali that can pass cars, even when they don't have cats. We live in small rural area, happens all the time.
I'd still like to have some stuff on it, though. atleast the EGR.
I'll eventually, get LT headers then put my flowmaster's on.
I want to keep the EGR with the windstar+split port swap. will all of that swap over and fit in the mustang?
I'm looking into the 99-03 windstar intakes, I like how they look.
Old 08-26-2014, 07:52 AM   #2
Bravebowhunter's Avatar
Those newer Windstar Intakes will not fit under a stock hood need a cowl induction hood
1967 coupe 351w 5 speed dual exhaust long tube headers, 2000 v6 5 speed dual exhaust lowering springs drilled and slotted rotors, 2005 ford ranger single cab 3.0 under drive pulleys auto 8.8 rear end with 4.10 gears
Bravebowhunter is offline   Reply With Quote
Old 08-26-2014, 06:44 PM   #3
Blue Angel's Avatar
Whats the difference between the 99-03 windstars n the others? Y wont it fit?
Sent from my SPH-L710 using Mustang Evolution mobile app
Blue Angel is offline   Reply With Quote
Old 08-26-2014, 08:01 PM   #4
The 96-98 Windstar intakes are a flat design those newer ones are taller.
Old 08-26-2014, 08:16 PM   #5
Blue Angel's Avatar
Same look tho? Just taller? I have a 3in cowl hood so it will fit?
Old 08-26-2014, 08:29 PM   #6
No the two intakes look completely different the older one looks similar to what's on our cars now but the throttle body is in the front of the engine and with the two runners going down the sides then the runners goin into the lower intake the newer one looks like the new coyote motor design like you said. Yes the 3 in. Cowl hood should fit the newer style intake under it.
Old 08-26-2014, 09:12 PM   #7
Blue Angel's Avatar
Is there any significant difference in power and tq between the 2 or is it just different styles
Old 08-26-2014, 11:53 PM   #8
lemons95's Avatar
I read that the newer one flows the same, its the heads and lower intake holding the 99-03 back.
Looks a lot nicer to me.
I don't want it to say 3.8 split port on it, since I have a 4.2.
I'd like to get a 5inch cowl,with a cobra front bumper and fog lights. Won't put any cobra emblems or anything just the bumper.
Sent from my LG-MS770 using Mustang Evolution mobile app
Old 08-27-2014, 01:17 AM   #9
Blue Angel's Avatar
Damn 5in? I can bearly see from my 3in lol. So can I port the lower intake wit a windstar? Could I port the windstar too?
Old 08-27-2014, 05:26 AM   #10
I've read that the newer Windstar intake does produce better numbers then the older one but if you want to keep the stock hood your stuck with the older one.
Windstar swap? Venomouz831 Pre-2005 V6 Mustang 7 02-27-2012 01:13 PM
windstar kit, melting egr silicone hose, will this work jblitz99 Pre-2005 V6 Mustang 4 02-12-2012 06:13 PM
Windstar upper intake swap Supersixx Pre-2005 V6 Mustang 10 06-14-2011 05:21 PM
Windstar Swap --PICS-- mystanghurts04 Pre-2005 V6 Mustang 71 05-22-2010 08:28 AM
windstar swap lemkerailroad1 Pre-2005 V6 Mustang 4 05-18-2010 11:59 AM
09:52 PM
