Alignment - Mustang Evolution
Old 08-27-2014, 04:12 PM   #1
PiojoA7x's Avatar
Alignment
I went to an alignment shop today and I notice that the guy was under my car adjusting my tie rods of course. But he didn't touch the SR camber plates I installed. I lowered my car so thats why I went to get an alignment. Why he suppose to adjust my plates too or no?
PiojoA7x is offline   Reply With Quote
Old 08-27-2014, 06:17 PM   #2
If it's already in spec then no he doesn't. Did you get a print out of your caster/camber/toe specs before and after the alignment?
Old 08-27-2014, 10:49 PM   #3
Mile high JDF's Avatar
Did you mention to him that you installed the plates? Most shops set the toe and ship the car on its way while charging extra for adjusting caster and camber
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 08-27-2014, 11:18 PM   #4
PiojoA7x's Avatar
Yeah I did get a print out before and after
Old 08-27-2014, 11:20 PM   #5
PiojoA7x's Avatar
I didn't mention to him. If he didn't take a look at my plates, does it mean my car didn't get an alignment right?
Old 08-27-2014, 11:36 PM   #6
Post a pic of the print out.
Old 08-27-2014, 11:55 PM   #7
Not necessarily. We'd have to see the specs to know for sure. Most modern cars have non-adjustable caster and camber, which means the factory spec is designed into the chassis. The only way it will change is if the car is in an accident or has aftermarket C/C plates like you do. Most shops will just set the toe since that is the only adjustment that can be made to the vehicle unless they are told it has aftermarket plates on it.
+1 to this
Old 08-28-2014, 08:19 PM   #8
PiojoA7x's Avatar
Here is the report.Click image for larger version
Name:	ImageUploadedByMustang Evolution1409278765.473884.jpg
Old 08-28-2014, 08:39 PM   #9
You caster and camber actually look pretty good, as long as they're fairly close to the middle of the spectrum then you're fine. The only thing I could see is maybe going pre towards the middle of the range on your aber. Neutral aber isn't the worst thing though
Old 08-28-2014, 08:55 PM   #10
PiojoA7x's Avatar
So adjusting the plates won't be necessary?
Old 08-28-2014, 08:55 PM   #11
Nope, you should be fine.
Old 08-28-2014, 08:56 PM   #12
PiojoA7x's Avatar
Thanks for the help 👍
frame alignment Dark02Pony Pre-2005 V6 Mustang 13 12-20-2005 10:12 AM
oil change. alignment. loss of power Dark02Pony Pre-2005 V6 Mustang 19 10-21-2005 10:39 PM
Alignment problem stang-rookie Pre-2005 V6 Mustang 13 06-14-2005 08:35 AM
Minor collision, now alignment fubar. 88SC 1979-1995 Mustang GT 6 07-31-2004 07:44 PM
alignment question BlueDonkey Pre-2005 V6 Mustang 5 02-28-2004 08:17 PM
04:38 AM
