Vacuum Line Mystery - Mustang Evolution
Old 08-28-2014, 05:09 PM   #1
xfree143's Avatar
Vacuum Line Mystery
This photo is from the passenger side of my 2003 V6. I'm not sure where this vacuum line should go, I capped it off and it's not throwing any error codes. It's for sure not the vacuum line for the air condition ducks in the car.
Name:	ImageUploadedByMustang Evolution1409267367.338421.jpg
xfree143 is offline   Reply With Quote
Old 08-28-2014, 05:28 PM   #2
On my 01 there are TWO vacuum lines that run through the firewall into the interior of the car on the passenger side. Both of the vacuum lines branch off of a single vacuum line.
See if you can locate the vacuum line that is routed to that side of the car from the intake manifold. There must be a "Tee" or a "Y" or something of that sort that it plugs into.
You're going to have a vacuum leak until you find it...
Old 08-28-2014, 05:39 PM   #3
xfree143's Avatar
Well it's not a stock setup with the manifold and the vacuum lines
Name:	ImageUploadedByMustang Evolution1409268815.884433.jpg
That was on a tee with the other line going into the firewall but when I had both lines hooked to the tee and one source from the manifold my air ducks in the car would change from defrost to the any other vents. I used my vacuum line tester and could build up pressure and get my vents to move. When I tried it on the mystery line I could never build up pressure. So that is either an open line or some large volume tank connector.
Old 08-28-2014, 06:01 PM   #4
As long as there are no leaks on the vacuum side it shouldn't be a problem then.
It sounds like that line isn't connected to anything...
Vacuum line trouble 67mustang97 1996-2004 Mustang GT 4 04-26-2013 06:26 AM
vacuum line diagram for gt40 intake FLAT BLACK GT 1979-1995 Mustang GT 0 11-22-2012 02:26 PM
sea foam + vacuum line joey18 Pre-2005 V6 Mustang 7 07-21-2012 11:28 PM
1999 Mustang 3.8L vacuum line connection help dscott4410 Pre-2005 V6 Mustang 3 06-19-2012 08:13 AM
Sea Foam in vacuum line? afree05 2005-2010 V6 Mustang 1 12-12-2011 12:23 AM
05:07 PM
