swapping 3.55 gears in a 2000 v6 mustang - Mustang Evolution
Old 08-28-2014, 08:39 PM   #1
i wanna swap to 3.55 gear ratio in to the rear of my 2000 v6 mustang. im wondering what concerns i should have such as if i need more splines on my axels or if i could use the stock ones.... any information would be great as im trying to weigh my options out
thanks,
cory
corymartucci is offline   Reply With Quote
Old 08-29-2014, 01:24 AM   #2
mazen123's Avatar
Its a waste of time to go from 3.27 to 3.55 man
mazen123 is offline   Reply With Quote
Old 08-29-2014, 03:44 AM   #3
What do you think I should go them maybe 3.73?
Sent from my PantechP8010 using Mustang Evolution mobile app
Old 08-29-2014, 03:48 AM   #4
What do you think I should go? Maybe 3.73?
Old 08-29-2014, 07:28 AM   #5
Mile high JDF's Avatar
You'll need a gear install kit, but you won't need to go to higher spline count axles. I kind d of agree on skipping 3.55s, I've had two sets now and hardly noticed a difference when I swapped the first set in.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 08-29-2014, 08:08 AM   #6
Okay cool I'll probably run 3.73 then 7.5" is there any conserns I should look for such as timeings and rotation pressure that you would know of?
Old 08-29-2014, 09:32 AM   #7
Are you gonna install it yourself?
Old 08-29-2014, 09:42 AM   #8
Yes I have all the tools I should need so I'm trying to find out every problem I could run in to. I have a press for all the bearings and i have a tuner for the rpms and MPH
Old 08-29-2014, 10:49 AM   #9
I don't remember the specs off the top of my head any more, I did mine back in January. Google or a Haynes manual should have the specs though
v6 mustang
2000 mustang :: 2000 Ford mustang kohli412 Member Garages 0 05-02-2013 05:26 PM
swapping stock for 4.10 gears Vile87 Pre-2005 V6 Mustang 2 12-04-2011 01:47 PM
swapping a 96 mustang 3.8 with a 2002 3.8 deerslazer Pre-2005 V6 Mustang 6 07-22-2010 01:03 PM
How-to: Swapping a late model, EFI 5.0 and a t-5 into your classic Mustang fast64 1979-1995 Mustang GT 8 05-29-2005 04:15 PM
08:54 AM
