Swapping 2000 v6 rear end gears to 3.73 7.5" - Mustang Evolution
Old 08-31-2014, 11:49 AM   #1
Could anyone explain how to properly shim the gears. I will be using 3.73 7.5" with stock axles and all new bearings thanks! Any help will be very usefull
Sent from my PantechP8010 using Mustang Evolution mobile app
corymartucci is offline   Reply With Quote
Old 09-01-2014, 10:00 PM   #2
Sluder4's Avatar
I might be wrong but you might wanna get an 8.8 before putting in 3.75 gears. Cause down the road you'll want an 8.8 rear end and you'll have to do the process all over again.
1999 V6 Mustang Dark Satin Green , SR CAI, BBK 65mm Throttle Body, Screaming Demon Coil Pack, SR Lowering Springs, Pioneer Stereo, 2 12' inch subs and 1600watt amp, Green Calipers,
Sluder4 is offline   Reply With Quote
Old 09-02-2014, 07:07 AM   #3
I was maybe considering that.. thanks but also what is it about the 8.8s that are better?? Benefits?
Old 09-02-2014, 12:03 PM   #4
Sluder4's Avatar
Well with adding more horsepower the 8.8s can handle more without failing, they are also equipped with a posi traction ...... Gah I forgot the dang word for it but it evens the distribution of the back wheels so that when you do a burn out it's not just one wheel spinning but both. The 7.5 doesn't have it. It's best to just find a 8.8 rearend and install it in that just so you'll get the most out of your new gears.
Sorry been a long day fourth class of the day my brains fried maybe someone else can chime on on the advantages and knows how to install gears as well. Supposedly it's pretty hard and you new a lot of tools to do it. Good luck tho!!!
Old 09-02-2014, 01:25 PM   #5
Thanks for the tips man! Will deffinatly will be looking in to it!
Old 09-02-2014, 07:10 PM   #6
Mile high JDF's Avatar
Limited slip differential
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 09-02-2014, 07:12 PM   #7
OP you're gonna need to experiment with shims. You will need the gear marker to check how the teeth engage each other, you can't have it set too far on the heel or the toe, and you don't want it set too tight or too loose. On top of all that you will have to make sure the backlash stays in spec as well.
Old 09-02-2014, 07:27 PM   #8
This should help. http://www.mustangcollective.com/sho...d.php?t=35119#
Old 09-02-2014, 08:44 PM   #9
Blue Angel's Avatar
Agree! I did my 373 n pozzi in my 7.5 but now I need a 8.8 with the new set up ima b running.
Sent from my SPH-L710 using Mustang Evolution mobile app
Blue Angel is offline   Reply With Quote
Old 09-02-2014, 09:21 PM   #10
Hey what's the reason you desided to up grade did the spines break or what?
Old 09-02-2014, 09:53 PM   #11
Blue Angel's Avatar
With the new set up im gonna get they might over time n I dnt wanna risk it
---------- Post added at 10:53 PM ---------- Previous post was at 10:53 PM ----------
Better to b safe den sorry
Old 09-02-2014, 10:24 PM   #12
8.8 > 7.5 in every single way possible
Old 09-04-2014, 02:17 AM   #13
lemons95's Avatar
I heard the 7.5 will break with any engine and a good set of tires(slicks probably)
The 8.8 will hold up to the power and won't break when you get traction.
Sent from my LG-MS770 using Mustang Evolution mobile app
Old 09-04-2014, 09:02 AM   #14
Sluder4's Avatar
Thanks for helping me clear that up guys!
But yeah get an 8.8 reared off a 99-04gt bolts right up and you'll have to have a shop to install them.
Old 09-04-2014, 01:27 PM   #15
Blue Angel's Avatar
Its easy to do wit 1 buddy. Bolt right up n 1 afternoon is all
Old 09-04-2014, 11:06 PM   #16
mazen123's Avatar
The 7.5 isnt that bad. Its much lighter than the 8.8 and it can handle 300rwhp while the 8.8 can handle 400rwhp. Guys with GTs cant even make 300rwhp in most instances lol. But yes slicks do destroy the 7.5s a lot lol.....
mazen123 is offline   Reply With Quote
Old 09-05-2014, 03:23 AM   #17
lemons95's Avatar
7.5 is only 10lbs lighter from what I read.
I can find parts for the 8.8 a lot easier too.
Old 09-12-2014, 04:04 PM   #18
xrsfx's Avatar
The 8.8's might not fit
xrsfx is offline   Reply With Quote
Old 09-12-2014, 04:24 PM   #19
How so?
Old 09-12-2014, 05:10 PM   #20
mazen123's Avatar
They will all fit from 79-04.... Although they will be shorter from different model years. The foxbody being the shortest and the 99-04 cars being longest
Old 09-12-2014, 05:16 PM   #21
lemons95's Avatar
A 99-04 will bolt up to a 94-98.
Old 09-12-2014, 05:27 PM   #22
xrsfx's Avatar
So if I get a 2000 gt rear end with 8.8 gears it'll fit in my 2004 V?
---------- Post added at 05:27 PM ---------- Previous post was at 05:27 PM ----------
V6
Old 09-12-2014, 05:28 PM   #23
V6
Yes
Swapping to a gt500 rear end Voltwings 2011-2014 V6 Mustang 35 09-30-2014 07:42 AM
Swapping stock v6 rear end gears to 3.73 corymartucci Regional Mustang Discussion 4 08-31-2014 12:14 PM
swapping 3.55 gears in a 2000 v6 mustang corymartucci Pre-2005 V6 Mustang 8 08-29-2014 10:49 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
10:53 AM
