M90 supercharger - Mustang Evolution
Old 08-31-2014, 12:27 PM   #1
AKE
AKE's Avatar
M90 supercharger
Does anyone have a m90 supercharger on there 99-04 mustang v6? I bought one to stick on and I just wanna make sure it can be done. I've only seen them on 94-98 v6's
AKE is offline   Reply With Quote
Old 08-31-2014, 12:28 PM   #2
AKE
AKE's Avatar
Here is a picture Click image for larger version
Name:	ImageUploadedByMustang Evolution1409509694.729239.jpg
Old 08-31-2014, 12:38 PM   #3
Rapinator126's Avatar
Wouldn't waste your time
Old 08-31-2014, 12:43 PM   #4
AKE
AKE's Avatar
What do you mean?
Old 01-27-2015, 11:31 AM   #5
I was just given a M90 by my boss, catch is i cant sell it, i have to install it on my 98 GT or give it back. I have recently purchased 2003 GT PI heads and intake, so i as well as yourself am trying to do the same thing. Have you had any luck?
trimpiper is offline   Reply With Quote
Old 01-27-2015, 11:39 AM   #6
We're you given the supercharger kit or just the blower?
Be the type of person who leaves a mark, not a scar
Old 01-27-2015, 12:38 PM   #7
Bravebowhunter's Avatar
It won't do anything on a gt. It can't push enough air for 8 cylinders people only put them on the v6's. It takes a lot of fabrication to get it on but people have done it.
Bravebowhunter is offline   Reply With Quote
Old 01-27-2015, 01:18 PM   #8
I was given the early 90's 3.8 M90, basically i was given the blower, the 3.8 outlet cover but not the long tube that says suppercharger, and the inlet tube that hooks directly to the supercharger but not the throttle body. He also gave me a 2nd 3.8 outlet cover that has been modified and raised about 1". I am brand new to forced induction and to be honest I really just want to make this a learning experience because i dont have 5k to drop in a new one but i have 1-2k to make this work if thats at all possible.
Old 01-27-2015, 01:22 PM   #9
I doubt there's a v8 conversion kit for that m90. But there are m90 supercharger kits for the 4.6 2v. Roush made one that's pretty good.
Old 01-27-2015, 02:22 PM   #10
well the 99-04 V6's have split port induction lower intakes, the M90 was made for single port. However if you want you can swap lower intake manifolds, or if you can find someone that can make an adapter plate that would work too. Good luck with your build.
99Stang6 is offline   Reply With Quote
Old 01-27-2015, 02:39 PM   #11
That M90 makes 12lbs of boost. It came off a t-bird super coupe. So it will wake up a 4.6 2v if can get an adoption plate as mentioned. I've got an M90 on my Roush but it can only stand around 10lbs before getting heat soaked. Drove a stock 3v gt and then my car and the difference is phenomenal...
Old 02-14-2015, 01:25 AM   #12
Jmustang78's Avatar
Region: Montana
Send a message via Yahoo to Jmustang78
That M90 came of a 94-95 T-Bird SC & unless ur a good fabricator will NOT fit ur 4.6l! So I'd give it back to ur boss an tell him he is an idiot cuz he should have known that! Look into the roush or cobra blower they made and try that if u want a blower other wise look into supercharger a or turbos that are designed for the 4.6
Jmustang78 is offline   Reply With Quote
supercoupe m90 supercharger 3.8boii Pre-2005 V6 Mustang 4 04-19-2010 10:48 PM
Eaton M90 Supercharger CCT4132 Pre-2005 V6 Mustang 5 09-15-2009 02:46 PM
Roush M90 Supercharger SaturnMan8227 Pre-2005 V6 Mustang 2 02-06-2009 07:32 AM
m90 supercharger question????? 97 stang Pre-2005 V6 Mustang 17 11-17-2008 04:47 PM
Eaton M90 Supercharger for V6 Mustangs nmaraijko Mustang Parts for Sale and Wanted 10 08-10-2008 05:16 PM
07:28 PM
