Sea foamed the stang! - Mustang Evolution
Old 09-01-2014, 02:27 PM   #1
Shifty 5.0's Avatar
Just seafoamed for the first time today did the injector cleaner, trans tune, and upper engine clean and it did make a difference! The trans tune hasn't kicked in much needs about 50 miles but the throttle response and idle is a lot better and it put on a smoke show
Shifty 5.0 is offline   Reply With Quote
Old 09-01-2014, 02:50 PM   #2
I would probably try it but 2 much smoke
TurboCobra is offline   Reply With Quote
Old 09-01-2014, 03:26 PM   #3
Shifty 5.0's Avatar
The smoke isn't bad lol
Old 09-01-2014, 03:30 PM   #4
Trans tune is added to fluid? You have to flush the fluid after a few miles put on it, correct?
Old 09-01-2014, 03:33 PM   #5
Shifty 5.0's Avatar
You can use it before a flush or drain and fill or as a conditioner when you have fresh trans fluid. I changed my fluid and trans filter because the trans started kicking and about 3,000 miles after the change the fluid is still clean so I added the trans tune
Old 09-01-2014, 05:04 PM   #6
OK
Old 09-02-2014, 04:44 PM   #7
Just wanted to mention something cause I care about my Mustang bruthas-
*Adding trans tune to fluid and driving with it in the trans, worries me a tiny bit. It's most likely just fine. Just a FYI- for auto's and manual tranny's, using synthetic has been a staple of mine. If you do use synthetics, they have very strong detergents inside and maybe provide the same effects as trans tune, but much safer, or conventional like.
**Also, I use synthetics in my differential (Amsoil & FRPP friction modfr), tranny (Mobil1ATF), power steering sump (Mobil1 ATF), Engine (Mobil1 ES). Also use Militec1 additive. Motorcraft oil filters.(used to use Mobil1 or K&N oil filters).
If u think of it, update me sometime down the road on how it worked. -I do remember you saying that it was hesitating or something similar too which may of been main reason.
Just want to be helpful, no disrespect Brudda!!
Old 09-02-2014, 08:56 PM   #8
Shifty 5.0's Avatar
None taken! But yeah it's been shaking when downshifting from high speeds so went with a drain and fill and new trans filter and heard the seafoam trans tune does help it. I know it's not a miracle worker but anything to avoid getting a new trans. But I will let you know down the road if anything changes
Deep Sea Fishing Trip June Brent The Bar 14 11-30-2010 03:36 AM
Panama City Deep Sea Fishing Pictures Brent Pictures and Videos 6 11-08-2008 11:23 PM
Sea Foam 00vertstang Pre-2005 V6 Mustang 8 10-28-2004 06:19 PM
07:03 AM
