Window - Mustang Evolution
Old 09-03-2014, 09:45 AM   #1
MigV6stang's Avatar
Region: Arkansas
Window
Anyone have problems with their Windows never wanting to roll up or down on their new edge mustangs? One Day My Drive Window works the next it dont tips on how to solve this? Please and thanks
StreetStangMiggz
MigV6stang is offline   Reply With Quote
Old 09-03-2014, 11:09 AM   #2
Close the door really hard. Is a bandaid fix but it'll work
Old 09-03-2014, 11:35 AM   #3
MigV6stang's Avatar
Region: Arkansas
I've tried banging it as hard as I can I even kicked it but I'll try that too thx
StreetStangMiggz
Old 09-03-2014, 11:37 AM   #4
Pony_Boy's Avatar
My explorer, similar year, had a connector issue for the driver window regulator. Try cleaning up the connection?
You know that warm and fuzzy feeling? That means something bad is about to happen...
Pony_Boy is offline   Reply With Quote
Old 09-03-2014, 11:41 AM   #5
MigV6stang's Avatar
Region: Arkansas
Wth lol
StreetStangMiggz
Old 09-03-2014, 12:50 PM   #6
Sluder4's Avatar
They had a recall on our year mustangs for the windows. Only fix is taking it to a dealership and they put a while new window and frame and stuff in it. About 220 to fix just one....
1999 V6 Mustang Dark Satin Green , SR CAI, BBK 65mm Throttle Body, Screaming Demon Coil Pack, SR Lowering Springs, Pioneer Stereo, 2 12' inch subs and 1600watt amp, Green Calipers,
Sluder4 is offline   Reply With Quote
Old 09-04-2014, 12:29 AM   #7
MigV6stang's Avatar
Region: Arkansas
A ford dealership?
StreetStangMiggz
Old 09-04-2014, 09:00 AM   #8
Sluder4's Avatar
No didn't even go to the dealership I mean idk if they'll do it for free since it was a recall or they'll charge you 500 to do it. I went to a local place. Did a good job but now I have problems with the plastic pickin out an they scratched the paint behind the door panel...... But at least my window rolls up now and doesn't smack the top of my car when I close it
Old 09-04-2014, 10:33 AM   #9
MigV6stang's Avatar
Region: Arkansas
Damn so if I went to ford they charge me up the *** then.... **** ...I don't really wanna go to a small shop I don't trust any at all I thought about doing it myself too
StreetStangMiggz
Old 09-04-2014, 10:51 AM   #10
Window motor. My driver side went out on me. Replaced it and it works just fine
Old 09-04-2014, 11:50 AM   #11
Sluder4's Avatar
Well hopefully it's just the motor. If it's the motor you can do it yourself but if it's off tract and comes loose from the rest of the door then you'll have to go my route.
If it's the motor then it'll be a quick fix. Take one from the junk yard and put it in yours. Real easy to do.
Old 09-05-2014, 07:20 AM   #12
MigV6stang's Avatar
Region: Arkansas
That's what I thought about mine but it rolls up and down now the other day it got stuck again later when it got cooler like around 9 pm it started working fine I had my buddy kick the **** out of it it dint roll up so then I turned the key all the way and it it worked
StreetStangMiggz
Old 09-05-2014, 05:29 PM   #13
AKE
AKE's Avatar
One of my windows was doing that and it finally fell of the track and I put silicone and stuck the window back on the track and it works fine
AKE is offline   Reply With Quote
Old 09-05-2014, 05:31 PM   #14
AKE
AKE's Avatar
Also all you might have to do is just hit the motor and it may start working fine again. Sounds still but it works
---------- Post added at 07:31 PM ---------- Previous post was at 07:30 PM ----------
Silly*
Old 09-06-2014, 01:57 AM   #15
MigV6stang's Avatar
Region: Arkansas
That's what I been doing punching the heck out of it
StreetStangMiggz
Old 09-06-2014, 05:55 AM   #16
AKE
AKE's Avatar
No like take of the door panel and hit it with a rubber mallet
---------- Post added at 07:55 AM ---------- Previous post was at 07:55 AM ----------
Off*
Old 09-06-2014, 06:36 AM   #17
MigV6stang's Avatar
Region: Arkansas
Me bad I misunderstood haha
StreetStangMiggz
Old 09-06-2014, 06:42 AM   #18
AKE
AKE's Avatar
I think there is some piece in it that just get stuck or something. Idk but it might work cause don't cost anything
Old 09-06-2014, 10:54 AM   #19
MigV6stang's Avatar
Region: Arkansas
Thx bro
StreetStangMiggz
Old 09-06-2014, 08:49 PM   #20
Originally Posted by MigV6stang View Post
Thx bro
StreetStangMiggz
Stupid question but I'm curious cause of your signature but are you in one of the street stangz chapters
Old 09-06-2014, 09:59 PM   #21
MigV6stang's Avatar
Region: Arkansas
Naw just a car club I'm in from arkansas
StreetStangMiggz
Old 09-08-2014, 02:28 PM   #22
BamaStang93's Avatar
Same thing just started happening to me. Goes down, then later on won't come up. I'm starting off by replacing the switch .
---------- Post added at 02:28 PM ---------- Previous post was at 02:27 PM ----------
Update coming Wednesday
BamaStang93 is offline   Reply With Quote
Old 09-08-2014, 03:59 PM   #23
MigV6stang's Avatar
Region: Arkansas
I tried the switch it wasn't the switch well idk it might be with urs
StreetStangMiggz
Old 09-10-2014, 02:17 PM   #24
Well the reason I figure it's the switch is because when I unscrew the two screws that attach the switch to the door panel thing, lay on the switch and the wires under the switch start getting really hot. So if this doesn't work I'm trying the motor next.
Old 09-11-2014, 08:16 AM   #25
MigV6stang's Avatar
Region: Arkansas
Let me know what happens
StreetStangMiggz
Old 09-12-2014, 04:01 PM   #26
xrsfx's Avatar
The motor for the window just my be over heated. Mine does the same on really hot days
xrsfx is offline   Reply With Quote
Old 09-12-2014, 11:34 PM   #27
xfree143's Avatar
I finally just replaced the rails and motor and it fixed it.
xfree143 is offline   Reply With Quote
Old 09-15-2014, 09:04 AM   #28
Replaced motor and switch, turned out it was a bad regulator of course. At least I'm prepared for when the passenger side goes out.
96 SVT Cobra Rear quarter window and rear window louvers. Any good ones? Spiney SVT Mustang 4 04-05-2012 08:41 AM
window tinting DropTop_Stang Mustang Audio & Video 7 09-18-2003 07:58 PM
MSD Window Switch Question Joshness Pre-2005 V6 Mustang 22 08-04-2003 12:13 PM
riced out Stang outside my window... Stang01 The Bar 8 07-18-2003 10:13 PM
09:29 PM
