Won't drive - Mustang Evolution
Old 09-06-2014, 04:06 PM   #1
joe_117's Avatar
Won't drive
My car will start, but as soon as I put it in drive or reverse it shuts off. Please help!
joe_117 is offline   Reply With Quote
Old 09-06-2014, 04:51 PM   #2
When it is idling in park or neutral, how many RPM's is the tachometer indicating?
Will the engine stay running if you give it a little gas when you put the transmission in gear?
Old 09-06-2014, 04:57 PM   #3
joe_117's Avatar
It usually will be right under 1 in the RPMs but when I put it in drive or reverse it just quite. But it I put it in neutral an sorta rev it up an keep it there an put it In drive it will go. But if I make a complete stop with out having to put it in neutral an keep it rev up it will quit
---------- Post added at 10:57 PM ---------- Previous post was at 10:57 PM ----------
An now the RPMs is like half of 0 an 1 an it usually did not stay there
Old 09-06-2014, 05:06 PM   #4
could try cleaning your IAC and if that works go buy a new one.
does it shake and shudder when stalling or just shut off?
TurboCobra is offline   Reply With Quote
Old 09-06-2014, 05:06 PM   #5
It should be idling at about 750 RPM's.
How does the engine run otherwise? Is it missing or have you noticed a recent loss of power?
Old 09-06-2014, 05:07 PM   #6
natestang07's Avatar
My parents expodition did this and it was a vaccum leak
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 09-06-2014, 05:10 PM   #7
How does the engine run otherwise? Is it missing or have you noticed a recent loss of powe?
really? mine starts at like 1250-1500 then after 30 seconds will drop to 1k
Old 09-06-2014, 05:12 PM   #8
joe_117's Avatar
How much did it cost to fix
Old 09-06-2014, 05:14 PM   #9
In their case it was a matter of finding it which happened to be all the way in the back of the engine. It was just a cheap rubber coupling. It was like $15. Could be something to look for though
Old 09-06-2014, 05:14 PM   #10
Your car is an automatic also, isn't it?
The idle may be slightly higher on the auto cars.
500 is too low though...
Old 09-06-2014, 05:15 PM   #11
joe_117's Avatar
We'll when I turn it out on shakes my car a little bit. But before it would not shake. An the RPMs are different now. An i have to hold my foot on the gas to drive it or it will die
Old 09-06-2014, 05:16 PM   #12
joe_117's Avatar
It is an auto an it's at 500 normally it was 900 1000 RPMs before it messed up.
Old 09-06-2014, 05:19 PM   #13
Like Nate and TC both say, check for vacuum leaks first and there is also a chance that your Idle Air Control valve is malfunctioning.
Old 09-06-2014, 05:20 PM   #14
you say it stalls when you stop. Be careful and try putting it in neutral then coming to a stop. If it doesn't stall out then its your TC
Old 09-06-2014, 05:21 PM   #15
joe_117's Avatar
Abbreviated your name. But thanks for tellin me the possibilities! But I can still drive the car without making anythig worse???
Old 09-06-2014, 05:26 PM   #16
You can drive it but it isn't safe to have your car stalling all of the time so be careful and try to get this fixed ASAP.
Old 09-06-2014, 05:26 PM   #17
joe_117's Avatar
What do you mean stalling
Old 09-06-2014, 05:28 PM   #18
joe_117's Avatar
I am getting it checked monday. I will have this fixed because I can't afford to not drive. I have a job an school an the stang is my steed lol just kidding but yea I will have this fix asap
Old 09-06-2014, 05:29 PM   #19
lol I mean torque convertor. Its possible its not unlocking.
That or vacuum leak, dirty IAC, bad coils, boots/springs or plugs. dirty fuel filter or low fuel pressure.
Old 09-06-2014, 05:29 PM   #20
I mean your engine stops running.
And what TC meant when he said "tc" is your Torque converter.
Haha.
Old 09-06-2014, 05:31 PM   #21
joe_117's Avatar
Oh! We'll i just hope it doesn't cost much..:/
Old 09-06-2014, 05:34 PM   #22
I hope that it's nothing serious as well.
Let us know what you found the problem to be.
Good luck!
Old 09-06-2014, 05:35 PM   #23
joe_117's Avatar
I have another question. Could it possibly be a mass air flow sensor
Old 09-06-2014, 05:38 PM   #24
do you get a check engine light?
Old 09-06-2014, 05:39 PM   #25
joe_117's Avatar
Yes when this occurred the service engine soon light came on.
Old 09-06-2014, 05:44 PM   #26
perfect! is the light still on? go to autozone and have them connect there code reader for free and tell you the codes, make sure to write the codes down.
Old 09-06-2014, 05:46 PM   #27
Well find a way to retrieve the code and we will be able to tell you what's wrong.
Old 09-06-2014, 05:49 PM   #28
For some reason, none of the auto parts stores in CA will do that for you.
Its probably some "union" rule or something...
Old 09-06-2014, 05:51 PM   #29
well then go buy one from Walmart use it and return it lol
Old 09-06-2014, 05:51 PM   #30
Yea I've tried to have a few places do it. Doesn't seen like they are anymore.
Old 09-06-2014, 05:55 PM   #31
Haha.
They are wise to that "trick".
Most places charge a re-stocking fee on returned scanners...
Old 09-06-2014, 05:58 PM   #32
joe_117's Avatar
I will go their now!
Old 09-06-2014, 05:59 PM   #33
Nope.
I bought one at Harbor Freight.
And I only had to buy it because I was too careless to plug in one of my 02 sensors all of the way when I changed them.
Old 09-06-2014, 06:01 PM   #34
joe_117's Avatar
Il go now
Old 09-06-2014, 06:36 PM   #35
joe_117's Avatar
EGR vacuum regulator circuit, throttle pedal position sensor, EGR pressure sensor and intake air temperature senso
---------- Post added at 12:36 AM ---------- Previous post was at 12:36 AM ----------
That is what the thing tracked that is wrong with my car.
To drive or not to drive 2011 Kona Blue 2011-2014 V6 Mustang 41 01-26-2012 08:53 PM
68 coupe 289 lights come on but won't turn over and headlights won't come on Sixty8 Coupe Classic Mustangs 2 03-07-2009 07:52 PM
Look what x-mas gift i won on ebay! HELL YEAH!!!!!!!! Autobadges.com The Bar 17 11-08-2003 02:59 AM
Look what I just won on ebay hehehehhhe Danger Dude Pre-2005 V6 Mustang 18 11-03-2003 07:42 AM
Lookie what I won Yesterday at the meet!! Rellik The Bar 20 09-23-2003 08:11 PM
12:57 PM
