Ac blows threw floor and defrost only - Mustang Evolution
Old 09-08-2014, 01:02 PM   #1
95convertible's Avatar
Please help where do I start it's super hot where I live and I need ac !! Lmao I have it it just don't blow on face is it a vacuum line ?!?!
Matthew Erlinger
95convertible is offline   Reply With Quote
Old 09-09-2014, 08:41 AM   #2
TreyDeluxe's Avatar
I've got the same issue...took it to a shop and they told me that I had a broken guide door in the air plenum behind the dash (or the cable that moves this door is broken). When this guide door breaks the car automatically goes to defrost. He quoted me $1000+ cause he would have to pull the dash to fix it. So I said screw it.
TreyDeluxe is offline   Reply With Quote
Old 09-09-2014, 08:42 AM   #3
Maybe the door that opens to allow the a/c to go thru is broken. What I did for mine was pull out the center console. Turn on the a/c Where the vents are, stick your hand in all the way and see if there is a flap. You'll know if you opened it if you feel air blowing. For mine I cut a coat hanger to size, bent it, and braced the flap open against the console. See if that helps
"Joey" 2004 v6: SR CAI, MPT Tuned, 4.10 gears
Miri is offline   Reply With Quote
Old 09-09-2014, 08:46 AM   #4
TreyDeluxe's Avatar
If you do this you will never have defrost...or you will just have to pull your center console every time you want to swap from face vents to defrost and vice versa so...
Old 09-12-2014, 11:39 PM   #5
xfree143's Avatar
Had this problem and used a vacuum line tester to make sure everything inside worked. Ended up being the vacuum line connection on the engine
xfree143 is offline   Reply With Quote
Old 09-14-2014, 09:01 PM   #6
^ where did u get the acumen tester ... Also where was the line on the engine
Matthew Erlinger
Old 09-15-2014, 08:37 PM   #7
98projectpony's Avatar
I had the same problem for a little bit and mine was just a vacuum line broke by the fire wall just behind the intake manifold.
Sent from my SPH-D710VMUB using Mustang Evolution mobile app
98projectpony is offline   Reply With Quote
Old 09-16-2014, 11:39 AM   #8
davidcseifert's Avatar
Region: Arkansas
The small 1/4" line that goes into the passenger side corner of the engine bay is for vent controls, check it.
blower/new cam soon
Old 09-20-2014, 03:16 AM   #9
xfree143's Avatar
I bought the vacuum tester at the auto parts store, didn't pay much
5.0 floor mats dfw local pickup only godsdisciple85 Mustang Parts for Sale and Wanted 4 03-29-2013 11:44 PM
won't start and threw codes 2110 and 2107 07regency 2005-2010 Mustang GT 7 08-22-2012 09:27 PM
The fan in my car only is blowing threw defrost? Help 1995boss 1979-1995 Mustang GT 2 08-08-2012 04:54 PM
MY AC IN MY 1997 MUSTANG ONLY BLOWS THROUGH THE TOP AND BOTTOM VENTS WHATS WRONG...? hobbard 1996-2004 Mustang GT 1 08-24-2009 12:12 PM
rear window defrost not working Cobra GT 1996-2004 Mustang GT 3 12-16-2008 05:26 PM
08:02 AM
