Blowing fuses - Mustang Evolution
Old 09-08-2014, 09:13 PM   #1
Jaytraeg's Avatar
Blowing fuses
So, I just got yet another mustang (the same one that I had the first time; long story, and I'll explain later), and I'm having a small problem already. My fuse number 8 in the footwell keeps blowing everyone I stick a new fuse in it. Amy suggestions?
Sent from my iPod touch using Mustang Evolution
Jaytraeg is offline   Reply With Quote
Old 09-13-2014, 09:45 PM   #2
Are you sure you're using the right fuse?
Branderino is offline   Reply With Quote
Old 09-14-2014, 09:28 AM   #3
Bravebowhunter's Avatar
What is that fuse for?
1967 coupe 351w 5 speed dual exhaust long tube headers, 2000 v6 5 speed dual exhaust lowering springs drilled and slotted rotors, 2005 ford ranger single cab 3.0 under drive pulleys auto 8.8 rear end with 4.10 gears
Bravebowhunter is offline   Reply With Quote
Old 09-14-2014, 11:04 AM   #4
Jaytraeg's Avatar
Yeah, I'm using a 10. And the fuse is number 8 in the picture. Click image for larger version
Name:	ImageUploadedByMustang Evolution1410714246.131406.jpg
Old 09-14-2014, 11:06 AM   #5
Do you have an aftermarket radio or illumination?
Old 09-14-2014, 12:57 PM   #6
Jaytraeg's Avatar
Well, the dude that had it before me threw one in, and it was working sort of weird when I got it. It would only turn on sometimes, and the volume knob didn't work. That being said, it still turned on sometimes. I took it out, and it continued to blow fuses. Assuming that this is the problem, what should I do to try and solve the problem?
Old 09-14-2014, 01:11 PM   #7
That's probably it. I would take it to a radio/speaker shop. Or if you want a cheaper solution you could just put in a bigger fuse but that's kinda risky
Old 09-14-2014, 01:12 PM   #8
Jaytraeg's Avatar
Haha already tried a bigger fuse. Went to 20 before I got scared, but still blew it.
Old 09-14-2014, 03:15 PM   #9
Unplug your radio and pop a new fuse in and see what happens
Old 09-14-2014, 04:46 PM   #10
How are your mirrors? Do they work?
Old 09-14-2014, 04:47 PM   #11
Yes. I've never had a problem with my mirrors
Old 09-14-2014, 04:49 PM   #12
Maybe check your wiring kinda sounds like you have a short which would be a wire where the insulation has worn off and it's shorting to a ground drawing more amps
Blowing fuses d_1212 1996-2004 Mustang GT 3 07-01-2013 10:36 AM
Fuses Randl114 1996-2004 Mustang GT 4 11-11-2010 04:48 PM
Shouldnt have messed with the fuses Zebs5408 Pre-2005 V6 Mustang 6 06-14-2010 09:10 PM
'91 Civic New Dash Blows Fuses OsirisGuy General Car Discussion 7 04-23-2009 12:50 PM
High Current Fuses? jwarburton Pre-2005 V6 Mustang 1 10-13-2005 12:58 PM
04:48 AM
