HELP..Horrible popping/groaning noise when I turn... - Mustang Evolution
Old 09-08-2014, 10:46 PM   #1
TreyDeluxe's Avatar
98 Mustang. 130k. So I've had some issues for a while now which are high steering wheel vibration at speeds greater than 55 and when I apply my brakes the car pulls heavily to the right. Now today there is a new issue...there is a horrible noise coming from the right side when I turn either direction. I can only describe it as a popping/clicking/groaning noise. It makes this noise whether I'm in motion or sitting still while turning the wheel. What the heck is going on?? I am mechanically inclined but I don't know the proper names of the steering/suspension system. HELP!?
TreyDeluxe is offline   Reply With Quote
Old 09-08-2014, 11:14 PM   #2
PonyBoyV6's Avatar
Had the same symptoms when my ball joints went out on my GT. Car would pull right on some roads while driving and higher speeds. Then once they finally went completely bad, it started with the deafening screeching and popping during turns and over bumps. Might be the culprit.
PonyBoyV6 is offline   Reply With Quote
Old 09-09-2014, 09:57 AM   #3
Sluder4's Avatar
If not that you may need to get it aligned. Mine would have a terrible sound when I turned too and found it was way out of alignment.
1999 V6 Mustang Dark Satin Green , SR CAI, BBK 65mm Throttle Body, Screaming Demon Coil Pack, SR Lowering Springs, Pioneer Stereo, 2 12' inch subs and 1600watt amp, Green Calipers,
Sluder4 is offline   Reply With Quote
Old 09-09-2014, 07:50 PM   #4
mustang17's Avatar
Yep ball joint with me too. Could be that
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
HIDs, 20% tint, Mach 1 chin spoiler, Black bullitt wheels, White bumper inserts, Shorty antenna
mustang17 is offline   Reply With Quote
Old 09-10-2014, 06:54 AM   #5
GrabberMeBlue's Avatar
Popping when turning could also be front sway bar bushings. Crawl under there and see how they look.
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 09-12-2014, 07:00 PM   #6
TreyDeluxe's Avatar
Changed ball joints and front shocks..fixed!! Plus rides like a dream.
Sent from my HTC6525LVW using Mustang Evolution mobile app
Old 09-12-2014, 08:37 PM   #7
PonyBoyV6's Avatar
Glad everything worked out for ya, man. Nothing feels nicer than new suspension components.
Old 12-19-2014, 09:54 PM   #8
Right ball joint replaced today cured the screeching noise and pulling to the right when braking. Also, steering feels smoother. The pulling to the right problem started well before the noise.
silver02 is offline   Reply With Quote
Help with popping noise 11stangGT 2011-2014 Mustang GT 14 03-23-2014 12:43 PM
2nd gear popping popping out Cleancobra22 General Mustang Discussion 4 05-29-2012 08:36 PM
Weird popping noise from rear iwannagofast 1996-2004 Mustang GT 1 05-12-2009 12:10 AM
popping noise??? girlandherstang Pre-2005 V6 Mustang 8 06-28-2008 10:20 AM
Popping Noise 98StangGT 1996-2004 Mustang GT 8 08-04-2006 11:11 PM
05:50 AM
