Tighten clutch cable? - Mustang Evolution
Old 09-10-2014, 04:48 PM   #1
TreyDeluxe's Avatar
Ok so I have a little squeak coming from my clutch under the car..when I depress the clutch pedal slightly the squeak stops. So for a temporary fix until I change the clutch is there a way to tighten the cable so that the pedal has more tension on it??
TreyDeluxe is offline   Reply With Quote
Old 09-11-2014, 09:45 AM   #2
SonicBlueBerry's Avatar
I have the same problem. You can adjust the clutch buy lifting up on the clutch pedal for about 10 15 seconds with your foot while the car is on and then pushing it all the way in. If that doesnt do much its your throw out bearing that needs to be replaced.
SonicBlueBerry is offline   Reply With Quote
Old 09-11-2014, 10:18 AM   #3
TreyDeluxe's Avatar
Yes I know its my TOB but Im just looking for a temp fix until I can get a clutch kit. Thanks Ill try that.
Clutch or clutch cable acting up 99mustang99 1996-2004 Mustang GT 4 07-13-2013 12:38 PM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 03:53 PM
How much do I tighten the flywheel bolts on a 1967 Mustang? Burnard Classic Mustangs 2 12-11-2011 09:59 AM
What is the best way to tighten exhaust manifold? Nel86 1996-2004 Mustang GT 8 08-06-2011 02:57 PM
What can happen if i tighten my valve covers on to tight? donald Classic Mustangs 5 08-21-2009 09:36 AM
» Members Mustangs
98 V6
bmabbott
Chome
GTGirl
Add your Mustang
01:29 PM
