Car drives fast without touching gas - Mustang Evolution
Old 09-13-2014, 04:31 PM   #1
Iryan7's Avatar
Question Car drives fast without touching gas
Whenever I start my car and put it in drive, my car will go on its own. I don't mean the "normal" 1-3 mph. Sometimes my car will go 15-25 mph (on a straight road) without me ever touching the gas. Is this normal for these cars, or is something adjusted weird on my car? (Only owned it since March 2014)
Thanks in advance for any help guys.
Iryan7 is offline   Reply With Quote
Old 09-13-2014, 04:57 PM   #2
When the car is idling and you have it in gear, stopped, with your foot on the brake, how many RPM's is the tachometer reading?
Old 09-13-2014, 05:01 PM   #3
Iryan7's Avatar
Right at 750Click image for larger version
Name:	ImageUploadedByMustang Evolution1410649248.526853.jpg
Old 09-13-2014, 05:06 PM   #4
Ok. That's where it should be.
When you rev the engine to about 3000 RPM's, how long does it take for the RPM's to drop back down to 750?
Do they sometimes "hang" at around 1200 for a bit and then drop to 750?
This is with the car idling in park, of course.
Old 09-13-2014, 05:13 PM   #5
Iryan7's Avatar
No it falls right back down to just below 600 then 750
Old 09-13-2014, 05:21 PM   #6
Lol
You're not making this easy Ryan!
Ok. How about if the A/C is on, the engine is running and in gear, you're holding the brake, and you rev the engine a little, to maybe 1500 RPM's.
Do the RPM's drop right back down to around 700 or do they "hang" a while above 1000?
Old 09-13-2014, 05:25 PM   #7
Iryan7's Avatar
With AC on it does have a slight hang around 1,000
Old 09-13-2014, 05:27 PM   #8
man, crawl up under the dash and grab the pedal, lift it up and you should see some slack in the cable. Is it tight? pop the hood check the throttle cable and linkage, maybe something got jammed up.. I know that seems simple but its first thing I would check if my car was driving on its own lol
TurboCobra is offline   Reply With Quote
Old 09-13-2014, 05:30 PM   #9
Iryan7's Avatar
I'll give that a check in a second also, I forgot to mention when it drives fast it staying about 1,000 rpm. Hopefully that helps
Old 09-13-2014, 05:31 PM   #10
Ugh.
When it seems to be going 20-25 down a level road all on it's own, will it accelerate to that speed from a dead stop without touching the gas? Or is it just maintaining that speed after you let off the gas?
And does it do this all of the time? Or just sometimes?
Old 09-13-2014, 05:31 PM   #11
push all your cruise control buttons and check the cable as well. who knows could be stuck on some how
Old 09-13-2014, 05:35 PM   #12
Iryan7's Avatar
Originally Posted by straybullitt View Post
Ugh.
It will gradually get up to that speed without touching the gas. It doesn't take long on straight roads. Also, it always does this.
Old 09-13-2014, 05:48 PM   #13
Well it seems that your Idle Air Control valve is functioning reasonably well.
I'm somewhat suspicious that your speed sensor way be malfunctioning and is sending incorrect information to the computer.
These cars are designed to hold a higher idle when rolling so that the Hydro-boost system has enough power to assist with the power steering and power brakes.
I assume that your Check Engine Light is NOT staying lit, but I recommend having the computer scanned for trouble codes that may be "pending". There may be a clue to what is making your engine idle high, for so long, while the car is rolling.
Old 09-13-2014, 06:17 PM   #14
Iryan7's Avatar
Alright, I'll get that checked. Thanks guys
Old 09-13-2014, 06:22 PM   #15
If you don't live in California, most of the big auto parts stores will scan the computer for free.
Old 09-22-2014, 02:10 PM   #16
so how did you stop the ghost car?
Old 09-25-2014, 12:06 AM   #17
Iryan7's Avatar
Well I turned my idle down just a tad, but it still drives itself. So to put it simply, I didn't stop it. I'm just learning to live with it. Its not as bad as it was though.
Old 09-25-2014, 12:08 AM   #18
Iryan7's Avatar
Also, I had my codes scanned and nothing is showing up. Clueless.
Any tips on touching up aftermarket rims? Sandman 2011-2014 V6 Mustang 2 05-28-2013 08:28 AM
Touching up Plasti Dip RVAStang05 2005-2010 Mustang GT 10 12-29-2011 01:00 PM
A Touching Elephant Story Herbstang The Bar 9 01-08-2007 01:01 PM
Touching Tail Herbstang The Bar 6 09-14-2006 09:18 AM
Another touching moment the media never wanted to tell people about Seph The Bar 7 12-12-2004 08:46 PM
09:17 PM
