changing rear-end - Mustang Evolution
Old 09-15-2014, 03:49 PM   #1
changing rear-end
going to replace my stock 7.5 with a 8.8 and add a 7.3 racing gear. I found a GT rear end. 10.5 inch rear brake 62.5 inches hub to hub with top and bottom braces. it is a 3.27 ratio.
My car is a 99 3.8L custom dual exhaust with flow masters.
haven't bought it yet;
anyone ever done this? what surprises am I in for.
lwood7 is offline   Reply With Quote
Old 09-25-2014, 05:53 PM   #2
ruelas's Avatar
i recently replaced my rear everything gears, bearings, axles, posi and it seems that your only issue should be the driveshaft. You may need to get an adaption to make it fit on the tranny and the larger 31 sp for the 8.8, instead of the 28 sp for the 7.5
ruelas is offline   Reply With Quote
Old 09-26-2014, 05:14 PM   #3
fwalck's Avatar
It will be straight swap as long as it's a mustang 8.8 not a truck one and the 94-98 are a inch narrower then a 99-04 rear but they are also interchangeable
fwalck is offline   Reply With Quote
Old 09-27-2014, 04:33 PM   #4
I put the 3.7.3 gear with a LSD positive traction in the original 7.5rear end. my ABS light wont go out. the speed ometer is off by ten miles an hour and it burns more gas. I got a remarkable amount of torque. But was it worth 1000.00 I quess so.... I need to have the computer chip calibrated to get the speedometer right? other than buy a real V-8 mustang. what suggestions do you have. I have a V-6 has anyone done the mods. they offer at American muscle, where they have for 400.00 a chip mod with three different programs they write based on my particular car and mods.?
Old 09-27-2014, 05:13 PM   #5
ruelas's Avatar
The ABS issue is an ABS issue its not your change as far as the tuners is concern yes it would fix your problem but there are other means other people can do the job for you I have a Ford guy that can fix my speedometer issue
Changing out rear end Milehigh STK General Mustang Discussion 104 04-13-2014 12:23 PM
Changing Fluid in Rear End Questions? Dkerk8 General Car Discussion 10 03-20-2012 12:02 PM
Suggestions for changing the leaf springs under the rear end of a 1970 mustang.? fane Classic Mustangs 1 12-19-2011 08:59 AM
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 03:43 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
08:24 PM
