Built v6 vs. Coyote swap - Mustang Evolution
Old 09-22-2014, 08:47 PM   #1
stangcobra's Avatar
Ok so im wondering which seems like a better move (engine size and favoritism of a v8 out of the mindset). either do a forged stroger 4.3L build twin turboed or big centrifugal, or I do a coyote swap with a kennebell on top. Coyote and kb im looking at about 15g. The k-member and all the supporting mods will be done regaurdless of which build I do. Also I have too much money sunk in this car to "just go out and buy a cobra". Plus id be at the same price but at a much heavier car with much lower hp. So any thoughts?
Sent from my SPH-L600 using Mustang Evolution mobile app
stangcobra is offline   Reply With Quote
Old 09-22-2014, 08:52 PM   #2
Coyote
Old 09-22-2014, 08:53 PM   #3
Coyote
Old 09-22-2014, 10:07 PM   #4
08Mustang's Avatar
Do the 4.3 build, I always like more creative and different builds over the regular v8 swap! But then again a coyote swap would be sweet too haha
08Mustang is offline   Reply With Quote
Old 09-22-2014, 10:38 PM   #5
There is a coyote swapped New Edge GT with a VMP blower running 9s. Full weight street car and everything.
Old 09-23-2014, 09:01 AM   #6
stangcobra's Avatar
What is a vmp blower?
Old 09-23-2014, 10:55 AM   #7
Supercharger made by the company VMP.
Old 09-23-2014, 12:51 PM   #8
Bravebowhunter's Avatar
A built v6 would be way cooler and more rare. People generally don't build v6's. I want to build mine and supercharge it. Plus v8's weigh more. And what really matters when your racing is the power to weight ratio.
1967 coupe 351w 5 speed dual exhaust long tube headers, 2000 v6 5 speed dual exhaust lowering springs drilled and slotted rotors, 2005 ford ranger single cab 3.0 under drive pulleys auto 8.8 rear end with 4.10 gears
Bravebowhunter is offline   Reply With Quote
Old 09-23-2014, 01:03 PM   #9
stangcobra's Avatar
Ive also been weighing the idea of a 4v dohc 4.6
The coyote seems like it is a bit too much of a headache for swapping and once its in there is really not enough room to do even a simple tune up.
The 4v I could mount a twin screw on top since I like the whine more than the whistle. But im basically in debate mode right now. Lol
Old 09-23-2014, 01:09 PM   #10
In this case the V8 will actually weigh less. Coyotes have a lot of lightweight parts as well as their aluminum block and heads. The older V6 that OP has is a cast iron block with other heavy parts.
Old 09-23-2014, 01:10 PM   #11
I considered a Coyote swap myself for my 2001 and quickly realized that it would be way too much work.
Old 09-23-2014, 06:05 PM   #12
Well now he's talking 03-04 cobra motor and that would weigh more.
Old 09-23-2014, 06:19 PM   #13
He could use a Teskid block, bolts right up to everything else and is pretty light.
Old 09-23-2014, 10:41 PM   #14
Fender868's Avatar
Screw it, if you want to be creative and waste all the time and money in the world to make slightly better times, slap a 1.8 l inline 4 out of an Audi or something stupid and strap two turbos on it. If you want to do something partially creative and tremendously effective, than look no further than the coyote. You could always go Chevy ls1 or 4 or something of that nature, but honestly it's hard to best the coyote. It's an incredibly attractive engine and the build would be a lasting improvement. Not too mention, you will be turning heads at all sorts of car shows. Doesn't matter if you seen it once or twice, people will gather around to see a coyote crammed into a new edge. Guaranteed. It's a lot of work, but the result is so rewarding. You'll be grinning ear to ear for a long time
Fender868 is offline   Reply With Quote
Old 09-23-2014, 10:46 PM   #15
Fender868's Avatar
I know we've all seen this, but I can't get enough of it. Best of both worlds. Click image for larger version
Name:	ImageUploadedByMustang Evolution1411534002.192487.jpg
Old 09-23-2014, 11:00 PM   #16
Originally Posted by Fender868 View Post
I know we've all seen this, but I can't get enough of it. Best of both worlds. Attachment 166795
That was TJs old set up. Now he has the Cobra Jet intake and a 4" cowl. I like Calvin's better, the blue one with the TVS 2.3 on top.
Old 09-23-2014, 11:10 PM   #17
Fender868's Avatar
Yeah it's a nice one, but I'm a sucker for comp orange
Old 09-24-2014, 10:32 PM   #18
stangcobra's Avatar
I would never put the terminator motor in. Too heavey and the teksid can handle all the power id want and then some. My goal is 500-600 isnt going to be a drag car so dont need 800+ .....Although hp and torque are always fun... lol i also want the engine bay to be mechanically inclining, as in not having to yank the motor to do a tune up or change the starter. Thats y im starting to reject this swap. I love the 5.0 but the trade off in my opinion isnt worth the time id have to keep investing. Whereas the 4v 4.6 or the v6 are both easily accessible to do maintenance or modification. Still thinkin though.
Sent from my SM-T217S using Mustang Evolution mobile app
Old 09-24-2014, 10:45 PM   #19
LS swap
Old 09-25-2014, 12:14 AM   #20
davidcseifert's Avatar
Region: Arkansas
I vote V6
Andrew please jump off a bridge with the LS crap
blower/new cam soon
Old 09-25-2014, 04:40 AM   #21
Laquisha's Avatar
coyote
Old 10-03-2014, 09:46 PM   #22
stangcobra's Avatar
What about the 4.6L aluminator crate motor?
Old 10-13-2014, 10:02 PM   #23
Jmustang78's Avatar
Region: Montana
Send a message via Yahoo to Jmustang78
The coyote is a very desirable but costly motor unless u have connections. U can build ur v6 on a budget and get some very good power. Look at doing a 4.2 stroker with the t-bird SC set up added = blown stroker v6 <--- nice!!!
Jmustang78 is offline   Reply With Quote
2012 fully built turbo coyote Rapinator126 FYI Ads | Recently Listed 10 10-21-2013 07:12 PM
5.0 coyote swap angelofrat42 2005-2010 V6 Mustang 16 08-02-2012 07:14 PM
built b head tecksid vs termi swap way later mz98snake General Mustang Discussion 13 04-30-2011 11:15 AM
Coyote swap Snapple750 1996-2004 Mustang GT 12 03-30-2011 01:37 PM
07:11 PM
